Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: pro line 1966 F100 body
Old 04-28-2015, 11:16 AM   #1
Default pro line 1966 F100 body
Has anyone tried using prolines ford f100 body on the Ascender yet? I've got the body and was thinking of putting it on my Ascender instead of my scx10. But wasn't sure it would fit right. I'm wanting to mount it without reaming the body post holes, and use a stealth mount if possible to give it a more scale look.
If anyone has some pics or helpful wisdom, I'd be appreciative for any help given.
MikeMontgomery1970 is offline   Reply With Quote
Old 04-28-2015, 11:58 AM   #2
Default Re: pro line 1966 F100 body
If you have the body and the truck why not just set it on there and see how it looks?
With the adjustable wheelbase of the Ascender, you should be able to make it fit pretty easily.
K_Willis is offline   Reply With Quote
Old 04-28-2015, 08:30 PM   #3
I've sat it down on the truck a few times to get some idea of how it lines up, and to see how it would mount up basically. I'm just asking if someone else has used the body on the ascender before.
Old 04-29-2015, 04:05 PM   #4
Does it look right when you set it on the ascender? Are the tires gonna line up correctly with the wheel wells? And what wheel base are u running?
big knobs is offline   Reply With Quote
pro line 1966 F100 body - Similar Threads
1966 Ford F100 Body (Pro-Line) on CC-01 Chassis johninderby 1.9 Scale Rigs 6 02-02-2014 10:40 AM
New 1966 ford F-100 from Pro-line youngblood Paint and Body 14 01-12-2014 10:35 AM
Pro-Line K5 Blazer body on mini pro? mmatthews Losi Mini-Rock Crawler 3 08-03-2011 02:38 PM
