Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: Tamiya Tundra on Ascender?
Old 07-05-2015, 12:13 AM   #1
Default Tamiya Tundra on Ascender?
Haven't seen any posts on putting a tamiya tundra body on the ascender. Would love to try it. Anyone have the body and an ascender that can mock it up? Looks feasible but may be just to small.
lcbsc is offline   Reply With Quote
Old 07-06-2015, 02:40 AM   #2
Default Re: Tamiya Tundra on Ascender?
The tamiya hilift bodies are small. I have one on my SCX10 and those axles are almost too wide.
Deerhurst is offline   Reply With Quote
Old 07-06-2015, 06:39 AM   #3
When you narrow up the axles by the maximum 12mm, they end up the same width as the RC4WD Yota axles (180mm). The Tundra body is 216mm wide so you may be able to tuck the wheels in the fenders depending on wheel and tire choice.
The Tundra's wheelbase is 311mm which is a few mm short of the stock wheelbase of 314mm. Custom links or creative use of spacers will be required.
svt923 is offline   Reply With Quote
Old 07-06-2015, 12:06 PM   #4
Natedog's Avatar
Yes, they look good though.
Nice, it's very do-able either way with stock or narrowed Ascender axles depending on the look you want.
Old 07-06-2015, 11:37 PM   #5
Thanks for the replies. Was afraid body was slightly to small. Def want to be able to tuck, but have never trimmed axles or adjusted links before. Also afraid would flip easier on side hills.
BUT...really like the look and haven't seen on an ascender. Have to dig a little to see if I can get some tips on modifying everything.
Old 07-07-2015, 06:14 AM   #6
There isn't that many builds with the full Tundra body around because its $150+ to put together a new Tundra body. Most builds are cab only truggies due to the cost of the body.
Old 07-07-2015, 07:11 AM   #7
They sure do! With some small 1.9s and full droop they look like an artric super duty!
I easily have $100+ into my F350 HiLift body and dont have all the pieces for it.
Old 07-07-2015, 10:10 AM   #8
Actually truggy tundra not a bad idea...would probably still have to shorten axles though. Would axial honcho bed work you think? Who else makes them?
Old 07-07-2015, 10:16 AM   #9
Natedog's Avatar
Set it on the chassis and see how it looks, remove or raise/lower body posts and post a pic. You can always put it on and cut axles later if you want, Ascender front and rear axle housings are pretty cheap and my LHS has them in stock.
Yes, lots of money for styrene body. Detail is great though.
[QUOTE=Deerhurst;5257496]They sure do! With some small 1.9s and full droop they look like an artric super duty!
I easily have $100+ into my F350 HiLift body and dont have all the pieces for it.[/QUOTE
Yes.
Yes, maybe. Honcho bed will work if you're willing to cut it up a little too. I've cut up and modded my Honcho body several times on my Axial, it's easy.
Old 07-07-2015, 03:19 PM   #10
[QUOTE=Natedog;5257596]Set it on the chassis and see how it looks, remove or raise/lower body posts and post a pic. You can always put it on and cut axles later if you want, Ascender front and rear axle housings are pretty cheap and my LHS has them in
don't have the body yet, nor the honcho bed. May just have to go for it. I'll post pics if I do!
BTW, anyone have a honch bed they want to part with? Or tundra cab? 😉👍
Tamiya Tundra on Ascender? - Similar Threads
"White Python" 2008 Toyota Tundra Crewmax SR5 4dr Leer Cab Built with Tamiya Tundra clarketian 1.9 Scale Rigs 107 01-25-2016 05:16 AM
