12-09-2015, 08:44 PM | #1 |
Newbie Join Date: Feb 2015 Location: Little rock
| Rc4wd FJ40 body fit Vaterra platform??
Anyone know if the rc4wd fj body will fit the vaterra platform?
12-09-2015, 09:20 PM | #2 |
Pebble Pounder Join Date: Mar 2014 Location: Lenoir, NC
| Re: Rc4wd FJ40 body fit Vaterra platform??
The FJ40 is 10.8 wheel base. The shortest wheel base on the ascender is 10.95, it's a 3mm difference, or 1.5 per wheel, shouldn't be noticeable at all. Width: the stock ascender wheel width is only 1/2 inch more than the fj40. So yes it will fit, you'll have to do something to Hide the transmission, or run a front mounted trans with a transfer case. Would look pretty good imo. Sent from my VS985 4G using Tapatalk Last edited by BrotherAndySLB; 12-09-2015 at 09:31 PM. |
12-10-2015, 06:37 AM | #3 |
If you narrow the axle housings the maximum 6mm per side, they end up the exact same width as the Yota axles so no problem there.
12-11-2015, 08:37 PM | #4 |
This would be a sweet scale build!
12-14-2015, 08:11 PM | #5 |
thanks for the info!! yes thinking this would be a great scale build. Didn't think about the trans guess that would be in the way
12-14-2015, 11:08 PM | #6 |
It should be fine with transmission in stock center location, FJ40 body has plenty of room inside.
12-15-2015, 12:02 AM | #7 | |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
| Rc4wd FJ40 body fit Vaterra platform?? Quote:
The stock 10.8" wheelbase of the Gelande is actually a bit short for the Cruiser body, which is why most of the Cruiser builds you see extend the front axle by at least 5mm. Body mounting would take some work on the Ascender, but it should be doable. Last edited by new2rocks; 12-15-2015 at 05:39 AM. | |
12-15-2015, 09:55 AM | #8 |
The Ascender frame rails can be slid together even closer than the four factory sets of holes, cut off excess frame rails in the center so that they will slide together more , then drill your own new holes. At least one member on RCC has done it and posted pics, maybe userid OSRC? Hmmm....
12-15-2015, 10:47 PM | #9 | |
Newbie Join Date: Dec 2015 Location: Newhall
| Re: Rc4wd FJ40 body fit Vaterra platform?? Quote:
Hope those are helpful. Last edited by BAJA FJ40; 01-12-2016 at 09:47 PM. | |
01-06-2016, 05:09 PM | #10 | |
This is a new hobby for me, and I've already talked my two brothers and friend into joining the fun (4x4 1:1 owners and now Ascender owners). This is way more addicting than I ever thought it would be It takes awhile to get caught up on the acronyms, and terminology. Last edited by BAJA FJ40; 01-06-2016 at 05:11 PM. | |
Rc4wd FJ40 body fit Vaterra platform?? - Similar Threads | ||||
FJ40 Classic(RC4WD Body) on SCX10 (SSD;GCM) | yodi79 | Axial SCX-10 | 18 | 05-07-2016 10:31 PM |
Rc4wd FJ40 body fit Vaterra platform?? | Casecontrol | 1.9 Scale Rigs | 2 | 12-09-2015 08:19 PM |
Does the RC4WD Defender D90 Body fit the Trailfinder 2? | scale_freak | RC4WD Trail Finder 2 | 4 | 11-24-2015 02:26 AM |
How to fit Landcruiser FJ40/bushwacker body? | CentralCoaster | Axial SCX-10 | 3 | 06-24-2010 06:39 PM |
