01-22-2017, 01:12 PM | #1 |
Quarry Creeper Join Date: Jun 2013 Location: Canada
| '72 K10 body vs '66 F100
Does anyone have a side by side size comparison of the Ascender K10 body and the Pro-line '66 F100 honcho body? Or installed the F100 onto the Ascender cage? My brother and I are thinking about doing a couple vintage truggy builds using these 2 bodies and want to make sure they look reasonably scale together. |
01-23-2017, 10:13 AM | #2 |
Quarry Creeper Join Date: Aug 2016 Location: Or-eee-gun
| Re: '72 K10 body vs '66 F100
Proline has that 66 body as a 313mm wheelbase. Which I'm not sure how they'd judge wheelbase on a truggy body. Now I'm curious if it looks ok on the 290mm WB2 the K10 comes stock in. or if the front tires will miss the fenders.
01-23-2017, 01:21 PM | #3 |
Yeah i think they are just listing the Honcho wheelbase since its a direct bolt on for that truck. With a truggy there is obviously a great deal of flexibility on wheelbase. I am just concerned with how these 2 bodies would look together, i understand the other ascender bodies are on the large size. Near as i can tell they should be pretty close, but i can't even seem to find dimensions on the K10 body
01-23-2017, 01:31 PM | #4 | |
| Re: '72 K10 body vs '66 F100 Quote:
01-23-2017, 03:50 PM | #5 |
8 inches wide. 9 inches long and 4 3/4 inches high at the cab.
01-23-2017, 04:11 PM | #6 | |
I have the pro-line body here and it appears to be 8" wide 11" long and 6" tall. I gotta say, I'm surprised the pro-line is bigger, and by quite a bit, 2" longer, 1 1/4" taller. | |
01-23-2017, 04:18 PM | #7 |
Isn't the honcho an extended cab? Stock? That could account for the extra length. Edit: I also think the truggy rear on the K10 is longer than the honcho. |
01-23-2017, 04:33 PM | #8 |
Yeah, stock body is, but this F100 isn't. Pro-line also make a F250(12") and Silverado(12.5") honcho bodies that are both even longer, so idk. I guess i will have to come up with a different plan.
01-23-2017, 04:59 PM | #9 | ||||
Yes K10 tube bed is longer than Honcho tube bed. Might make it work with some cage/bed trimming? I love the K10 cab, but also love the Proline 1966 F100 cab! Quote:
If it fits Axial Honcho it should fit the Ascender, might have to adjust wheelbase on some though. | ||||
01-26-2017, 07:37 PM | #10 |
Go to Codyboys K10 thread. Post #21.
01-26-2017, 10:30 PM | #11 |
nice find, thanks
03-23-2017, 04:34 PM | #12 |
Well i decided to pick up the Chevy body, just to see how they looked next to each other. But the results are pretty disappointing. The width is fine and i could probably deal with the length, but the height of the cab and even the doors on the Chevy look really squat. The idea here is to build 2 vintage truggies together, but these bodies just look too goofy next to each other. Oh well, we will have to figure something else out. |
03-23-2017, 05:03 PM | #13 |
Thanks for side by side pics, I checked the F100 body at LHS last week and it looks fantastic, but it's huge. After measuring I figured I'd have to shorten it about 1", maybe trim the bottom of cab and open up the front wheelwells a bit to compensate for trimming the bottom. That's a lot of work on $40 body and then have to do outside paint and I might not like how it turns out after I cut it up. Wish Pro-Line or Vaterra would make a cab to go with the K10 cage/bed to fit Ascender 12.3" WB4.
03-23-2017, 09:43 PM | #14 |
Some useful cab and bed measurements thanks to userids: Hillbillrc and Durok! Measured my K10 and Honchos, height can be trimmed some and my Honcho has about 1/4" iirc trimmed off the bottom edge. K10 has not been trimmed. K10..........Cab..............Bed Length......9.25".............8" Width.......8".................8" Height......4.75"............4.375" Honcho.....Cab..............Bed Length.....11.3"..............6.75" Width........7.5"..............7" Height.......5.125"...........4.3125" According to Proline: 1966 Ford F-100 Cab Length.....11.125" (283mm) Width........8" (203mm) Height.......6" (152mm) 85 Toyota HiLux Cab Length.....11.31" (287mm) Width........8.0" (203mm) Height.......5.25" (133mm) |
'72 K10 body vs '66 F100 - Similar Threads | ||||
Bronco and K10 Body Options? | Fourflys | Vaterra Ascender | 2 | 01-11-2017 05:45 PM |
