03-22-2018, 12:47 AM | #1 |
Newbie Join Date: Jan 2018 Location: Lancaster park
| Dose any make portal axials for ascebder
Hey just asking cause I feel like to would get rid of the toruqe twist plus id like to get more axial clearance off the ground plus lower weight on the rig pics to show off my rig so far Sent from my SM-G955W using Tapatalk |
03-22-2018, 05:14 AM | #2 | |
Rock Crawler Join Date: Dec 2014 Location: Union Bridge, MD
| Re: Dose any make portal axials for ascebder Quote:
Sent from my XT1585 using Tapatalk | |
03-22-2018, 08:03 AM | #3 |
| Re: Dose any make portal axials for ascebder |
03-22-2018, 08:37 AM | #4 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Here is a link to the portals I built from ascender axles, but they would be way to expensive to start building?Codyboy's 46 Powerwagon Flatbed. It would be a lot cheaper to find a used set of axles some where. You would also need a custom transfer case to make up for the 2.3:1 gear reduction in the Trx4 portals. Ernie :Thanks Cary! |
03-22-2018, 08:45 AM | #5 |
MST makes portal axles. I'm not sure if they will be the correct size for the TRX-4.
03-22-2018, 09:08 AM | #6 | |
I wanna be Dave Join Date: Dec 2016 Location: san diego
of course the first thing that came to mind was CODYBOY portals, but so far he has the only set he made for his rig (look for his powerwagon thread here) second thing i thought of was the MST's, and they should fit just fine under the ascender. just make your links so they point the pinion angle correctly. that said, its not plug-n-play, but what you're asking... nothing will be. | |
03-22-2018, 09:28 AM | #7 | |
Sent from my SM-G955W using Tapatalk | |
03-22-2018, 10:15 AM | #8 | ||
Yes, MST is another option, but Traxxas is better design, quality and more parts availability. | ||
03-22-2018, 10:17 AM | #9 |
03-22-2018, 12:21 PM | #10 |
Pebble Pounder Join Date: Feb 2016 Location: Manchester, NH
Didn't Spaceman's "alter-ego" say he got rid of TT by mounting SCX 10.2 axles to his Ascender?
03-22-2018, 02:00 PM | #11 | |
I don't believe that he got rid of all his TT, but I could be wrong. I think as usual he was looking for someone to start something with!! Ernie | |
03-22-2018, 02:11 PM | #12 | ||
If you look at some other portals and want to get rid of your TT you need to make sure they are geared with a reduction, if not all your doing is adding a little clearance at the expense of raising your COG. Just my 2 Cents worth! Ernie | ||
03-22-2018, 02:22 PM | #13 | |
And yea maybe not worth the time and effort when there are more easier and cost effective ways to reduce tt Sent from my SM-G955W using Tapatalk | |
03-24-2018, 06:22 AM | #14 |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
I'm surprised no one has made a set of ring and pinions for the ascender to help with the torque twist. That would be the most economical idea. Also they make them in different gearing for the scx why not the ascender? I mean if someone made them everyone would buy them. Last edited by mgputer; 03-24-2018 at 08:34 AM. |
03-24-2018, 09:41 AM | #15 | |
JMO But I'm looking forward to helping you with your ascender! Ernie | |
03-24-2018, 09:48 AM | #16 | ||
But thanks for asking!! Ernie | ||
03-24-2018, 10:34 AM | #17 | |
Sent from my ZTE A2017U using Tapatalk | |
03-26-2018, 03:11 PM | #18 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
I thought somebody on here helped limit the torque twist by using a twin hammers rear axle.. on the other hand.. if there is a portal knuckle out there that has a regular 1/2 inch id it can be modified to work. once I received my turned down housings from CODYBOY (thank you sir) I realized.. anything can be done with the axles. I have narrowed my front axle an inch total and made it drivers side pumpkin. |
03-26-2018, 05:26 PM | #19 | |
Ernie | |
03-27-2018, 02:02 PM | #20 |
| Re: Dose any make portal axials for ascebder you will get pictures. don't worry. since I screwed up once more (buy once cry once) I have to use a rear housing for the front since I need/ want to clock my c hubs just a bit and the original holes would be to close for comfort. im saving the last 2 housings for a mini 1.9 pro build. but on a side note.. I thought for cereal somebody actually use an ascender front axle and a twin hammers rear axle for a rig. I must be mistaken. and also so I've just heard deadlock scx10.2 portals are coming out. so I wouldn't be surprised if those could be made to work. |
Dose any make portal axials for ascebder - Similar Threads | ||||
portal axials on ax10 axial............... | bob1961 | Axial AX-10 Scorpion | 8 | 04-03-2018 04:45 PM |
dose anyone make aftermarket ring & pinion ? | bill mossor | Vaterra Twin Hammers | 0 | 02-14-2015 12:19 PM |
what material dose everyone us too make a tube chasis | hpiontherocks | Newbie General | 3 | 08-06-2008 05:41 PM |
dose any one make a tube roll cage | JUSTGOINGSLOW | Newbie General | 9 | 11-02-2007 04:08 PM |
Dose anyone make 1/6 scale shafty | alterchristopher | Chit Chat | 14 | 04-15-2006 04:59 PM |
