Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Sister's Hammer ... "thumbs up"
Old 02-08-2013, 09:22 PM   #1
Thumbs up Sister's Hammer ... "thumbs up"
hiya ...
hope everyone is doing well ...
I am going to start a thread about my Vanterra Twin Hammer.
Its all stock now what ever mods i can think of doing i plan on doing. I did adjust the stock shifting servo to try and fix the binding problem, but it still binds. I am thinking i am going to replace the shifting servo asap.
I plan on making some body panels, I have some vinyl(?) material that is suppose to be used as a cutting board, thin and flexible. I am really hoping this stuff will hold paint, too.
have these to install behind the faux buckets, (i do plan on removing the paint) going to insert LEDs.
well making the panels, i am thinking of cutting the front faux buckets out and mounting them with LEDs installed on a new hood panel.
OH .. and a new driver..
going to drive it through the weekend as is and then break it down.
I will then be adding ...
servo winch
more leds
new esc n motor ... 3s?
plus more ...
also switching it over to my DX6i.
open to ALL suggestions on the shifting servo ...
I will be posting images as i go along of my changes, builds, and installs. If u want some info or a pic of something close up, LMK ...
thank you and thank you for watching!
Dominic
sisterfunk is offline   Reply With Quote
Old 02-08-2013, 09:29 PM   #2
Default Re: Sister's Hammer ... "thumbs up"
what light buckets are those?
sally1800 is offline   Reply With Quote
Old 02-08-2013, 11:08 PM   #3
there actually those caps that cover the buckets.
Old 02-09-2013, 10:10 AM   #4
hiya!
here is some stuff i got last night...
More stuff to come... building and driving today!
I still need ...
to switch to my DX6i
servo winch
esc and motor
servo for shifter
a sweet light bar ..
Add sticks to the panels ...
Dominic
Old 02-09-2013, 10:17 AM   #5
Nice job!
Love the light bar.
JC CRAWLER is offline   Reply With Quote
Old 02-09-2013, 11:12 AM   #6
awesome build, I cant wait to see this thing.
Erbing is offline   Reply With Quote
Old 02-09-2013, 11:30 AM   #7
I would say change the shift servo first, even after setting epa's on mine it burnt out in about 5-10mins today. or at least strip it down and centre the servo horn to the right location. then set epa's.
where are you thinking of mounting the servo winch? be interested to know!
southcrawler is offline   Reply With Quote
Old 02-10-2013, 10:39 AM   #8
what light buckets did you use?
look like tamiya highlift?
I have a ton of the axial buckets hope they fit, if not i'll order up some tamiya's...
mine arrives tomorrow at shop, and 3 more tuesday for retail.
bonedog is offline   Reply With Quote
Old 02-10-2013, 11:41 AM   #9
i'm interested to know what those round things you used for the lights are
http://www.rccrawler.com/forum/membe...3150-41403.jpg
SubyJeff is offline   Reply With Quote
Old 02-10-2013, 12:14 PM   #10
The shift servo should only be used while in motion, it will always bind when not moving I am one of the lucky ones.....no problems with mine and I never adjusted it
Like the lights
halfcab is offline   Reply With Quote
Old 02-10-2013, 12:34 PM   #11
In stock form I thought it was a pretty ugly rig. But with what you have done to it I like it a lot more. Would love to hear how it performs.
Frostman is offline   Reply With Quote
Old 02-10-2013, 02:15 PM   #12
yes, i used the tamiya high lift buckets. they are a bit smaller than the axial, plus have a reflective surface.
those are the fronts for the tamiya light buckets. the hole is where u would drop the screw and attach them. then add a sticker or some type of cover. Didn't work out ... as u could see. but there are lots of possibilities for these.
thanks!
I really like the way it is looking. i removed the stock roof panel and made one from the same material. looks great. (i will add a pic later)
I am also making a new smaller and brighter light bar this evening.
I will add pics this evening ....
thank you again for looking and commenting!
Dominic
Old 02-10-2013, 02:47 PM   #13
Any idea where a servo winch will fit?
Old 02-10-2013, 03:09 PM   #14
great info thnx! and you used a dab of shoogoo to lock'em in?
Old 02-10-2013, 03:35 PM   #15
sorry about that ....
Tonight i am ripping out the stock electronics ... my idea right now is to stand the servo up right against the steering servo. from there running a tube to the front for the line to exit. I plan on using air hose from a fish tank... to run the line. very flexible and i have it sitting around.
thats the idea right now.. i will take pics.
I used hot glue.. wanted to make sure there were going to be to my liking. main reason i dont want to shoo them down now. I do like them, but i like the new roof i did. I will put a pic up later tonight. I do plan on ordering a stock clear body sometime soon ... maybe paint it orange.
Old 02-10-2013, 08:51 PM   #16
heinie_21's Avatar
that's nice of you to buy a TWH for your sister!
heinie_21 is offline   Reply With Quote
Sister's Hammer ... "thumbs up" - Similar Threads
The "Rock Hammer" -AX-10 Proline Tuber KOH Arctic Fire Axial AX-10 Scorpion 3 09-20-2012 02:32 PM
PFC FNG's XR10 "Hammer Down" PFC FNG Axial XR10 33 07-08-2012 05:01 AM
DRCrawlGood presents "White Lightning and Black Hammer". DRCrawlGood Axial XR10 0 09-05-2010 04:46 PM
"Claw Hammer" has been finished w/pics jakhammer Tamiya TLT Crawlers 13 01-18-2006 02:32 PM
