03-12-2013, 02:39 AM | #1 |
Rock Crawler Join Date: Aug 2012 Location: 909 area
| ae-2 into twin hammers help
just installed a ae-2 esc into the twin hammers and now the esc just beeps constantly no forward or reverse can any help out a noob lol thanks fellas and before anybody posts did u search yes i did lol |
03-12-2013, 04:15 AM | #2 |
Quarry Creeper Join Date: Nov 2007 Location: WNC
| Re: ae-2 into twin hammers help
The AE2 has a motor turn limit. 19 turns I think, the stock TH motor is a 15 turn so you will need a slower motor also.
03-12-2013, 06:36 AM | #3 |
Pebble Pounder Join Date: Aug 2012 Location: Canada
| Re: ae-2 into twin hammers help x2 on that ..you will want to find 20t or higher if running that esc ...also for constant beeping , you may need to recalibrte the esc.once turned on ..hold the trigger back for full throttle til you hear some musical tones ..then go full reverse til you hear the same musical tone ..then release to neutral , i,m thinking this may help you out ..the esc will recognize the hammers stock 15t motor but will burn it up in no time ..hope this helps..
03-12-2013, 07:32 AM | #4 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
Naw my AE-2 runs the stock motor fine... if its a steady beep like every 1 second or so, it came unbound from the transmitter... rebind your radio and itll work just fine.
03-12-2013, 12:22 PM | #5 |
ill try that thanks fellas
03-12-2013, 01:03 PM | #6 |
re binded it and nada still same thing everything else works and tried the throttle thing but still just beeps and flashes green and red even tried it with the 20t worked fine when i had it in my wraith
03-12-2013, 01:13 PM | #7 |
Quarry Creeper Join Date: Oct 2012 Location: high desert CA.
aww man thats not good iv been having some problems simalar to this i put in a castle speed control in and now the only way to get it to work is turn on radio, plug in battery esc starts beeps, then no pwer, turn off radio while esc still on, and it activates normal beeping, turn on controler during beeping and it works fine,, dont no how to fix this..
03-12-2013, 02:57 PM | #8 |
when i take off my body everything works fine no problems maybe its pinching a wire some were
03-12-2013, 02:59 PM | #9 |
| Re: ae-2 into twin hammers help |
03-12-2013, 03:03 PM | #10 |
03-12-2013, 03:06 PM | #11 |
I had this same issue in an old scx10 and i PROMISE its the motor lead.
03-12-2013, 03:28 PM | #12 |
ima check that out but it doess it with both motors should i just strait solder them instead of using the stock bullet plugs? thanks for the help
03-12-2013, 05:12 PM | #13 |
Make sure that the connectors fit tight and don't have any play...
03-12-2013, 06:02 PM | #14 |
everything works thanks guys
03-12-2013, 06:03 PM | #15 |
03-12-2013, 06:06 PM | #16 |
yes right on the money thanks for the help
ae-2 into twin hammers help - Similar Threads | ||||
Yet Another Twin Hammers | Tin Soldier | Vaterra Twin Hammers | 12 | 02-19-2014 07:47 AM |
twin hammers | zim35 | Scale Comp Rules | 264 | 05-19-2013 09:54 PM |
Twin Hammers | Rock Concepts | Videos! | 4 | 01-31-2013 02:50 PM |
