01-27-2015, 12:11 PM | #1 |
Quarry Creeper Join Date: Aug 2007 Location: Prospect park
| twin hammers mild brushless ?
Hi Guy's I want to put a mild brushless in my hammers I now have a stock Tamiya 540 motor and like it for in the mountain but I want just a little more top speed in high for a little more fun. what should I go with 1650KV or 1950KV? any input will be great. |
01-27-2015, 01:23 PM | #2 |
Rock Stacker Join Date: Nov 2005 Location: Yay area
| Re: twin hammers mild brushless ?
what battery will you be running? a 2s with those low kv motors wont even be as fast as a silver can 540 I bet, depending on how you gear it. a silver can 540 is ~2600kv just for comparison. I'd probably look for something around 3100-3800kv, as with 2s it will be about the same as silver can performance on 2s, but pretty quick with a 3s. |
01-27-2015, 04:02 PM | #3 | |
| Re: twin hammers mild brushless ? Quote:
Remember the extra power of the brushless motor will make a truck go faster even if it has a bit lower RPM than a stock 540 motor because a 540 brushed motor has way less power to turn the gears and pull the weight of the RC. I think I am going to try the 1950KV | |
01-27-2015, 05:31 PM | #4 |
Depending on the style of brushless. For example, a 21.5 spec racing brushless motor is 1800kv. These are raced side by side with tamiya silver can 540 brushed cars in the same class, and run the same lap times. An 1/8th scale 1800kv would be 'faster' as it has more torque and could be geared much higher, but I didn't think you were planning to use an 1/8th scale motor in a TH. |
01-27-2015, 05:51 PM | #5 | |
Tamiya stock silver kit motors are 27 turn motors. Last edited by shenlonco; 01-27-2015 at 05:53 PM. | |
01-27-2015, 08:14 PM | #6 |
Rock Stacker Join Date: Dec 2014 Location: tulsa
i got a traxxas 3500kv brushless in mine, 22 pinion an stock spur, locked in low gear, an its real quick on 2s, and stupid on 3s. could only imagine what it does in high gear.
twin hammers mild brushless ? - Similar Threads | ||||
twin hammers brushless setup help | gsrcivic | Electronics | 12 | 05-28-2014 03:01 PM |
Twin hammers brushless | Honey badger 15 | Vaterra Twin Hammers | 4 | 03-27-2014 01:25 PM |
