02-25-2015, 08:24 PM | #1 |
Newbie Join Date: Sep 2014 Location: west newton
| shock oil ?
I'm building a stock twin hammers for rock crawling only. I like a slow rebound & the book calls for 60w front 70w rear but Sr.Irie & gillbily23 runs 20w front & rear . I'm going to try 20w & see how I like it, but was wandering if anybody else runs something different in a rig used for rock crawling only ?
02-25-2015, 09:50 PM | #2 |
Rock Stacker Join Date: May 2013 Location: Brownsburg, IN
| Re: shock oil ?
If you want slow rebound then 20wt is not going to give you that unless you run a solid piston with no holes and use only the small difference in diameters of the piston and shock body to allow the oil to pass through. You will be better off going with the thicker oil if you want slower compression and rebound or you can use a piston with less holes in it.
02-26-2015, 04:19 PM | #3 |
| Re: shock oil ?
Thank you for your input.
03-02-2015, 06:35 PM | #4 |
Newbie Join Date: Nov 2014 Location: Las Vegas
| Re: shock oil ?
I have 40wt in the front and rear of mine, does pretty good. Sent from my iPhone using Tapatalk |
03-02-2015, 07:23 PM | #5 |
Pebble Pounder Join Date: Oct 2011 Location: Wichita
| Re: shock oil ?
I only use enough 15wt oil to keep things lubed and just let the springs do the work on mine. Strictly used as a crawler/trail rig, all slow going as I'm locked in low.
03-06-2015, 10:56 AM | #6 |
| Re: shock oil ?
Thank you for your in put, I found 2 tubes of losi 32.5w in the box the kit came in I'm going to start there.
07-26-2015, 08:47 PM | #7 |
Newbie Join Date: Jan 2005 Location: cabot
| Re: shock oil ?
40wt front and rear makes me happy, its also what i had on hand
07-28-2015, 09:52 PM | #8 |
Rock Crawler Join Date: Jul 2005 Location: Playing with toys with my son's
| Re: shock oil ? |
shock oil ? - Similar Threads | ||||
motor oil as a shock oil? | Mr.JayDeeM | General Crawlers | 10 | 09-02-2012 10:59 PM |
Shock oil and shock spring help | entropy | General Crawlers | 10 | 01-29-2011 08:40 AM |
best shock oil and gear oil | j4k3 | Axial SCX-10 | 2 | 07-26-2010 12:48 PM |
shock oil | Ryan33 | Newbie General | 1 | 10-28-2008 06:21 PM |
shock oil | Wicked_Jester | Newbie General | 2 | 02-01-2007 10:36 AM |
