Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Rear link lengths?
Old 01-03-2016, 12:25 PM   #1
Default Rear link lengths?
I found that the lower trailing arms are 119mm eye-to-eye. Can anyone confirm that and also have the length of the upper links?
MNorby is offline   Reply With Quote
Old 01-03-2016, 12:29 PM   #2
Default Re: Rear link lengths?
116mm & 103mm
89redranger is offline   Reply With Quote
Old 01-03-2016, 12:30 PM   #3
ah, ok. Thank you
Old 01-03-2016, 12:32 PM   #4
After measuring again just because I couldn't remember, the uppers look to be 102.5mm eye-eye.
Old 01-03-2016, 12:38 PM   #5
If you're making your own links try the uppers at 105mm and in the lower hole in the tub. That's how I have mine set up now, and it's better than any setup I've tried yet. Including raising the uppers at the axle. Just keep the ride height low to make the best of the factory geometry. These weren't meant to be tall cars and raising them puts the rear axle at a terrible point in the suspension's geometry and raises link angles. Same goes for the front really.
Old 01-03-2016, 12:51 PM   #6
Actually want to use twin hammers trailing arms in a bomber to shorten the wheelbase. Probably to to find some blue monkey ones unless there are other brands to look for? Uppers will be too short for this.
Old 01-03-2016, 01:15 PM   #7
Blue Monkey may be your best bet. They use Revo ends on both ends, meaning you could also use a Jato end, which is longer, to adjust the length. Should put you about where you need. Check BMRC's site though, they list the lengths with different rod ends.
Old 01-03-2016, 02:41 PM   #8
As in the Axial Bomber?
Ca. Off Roader is offline   Reply With Quote
Old 01-03-2016, 03:34 PM   #9
Yeah
Sent from my SM-G920V using Tapatalk
Old 01-03-2016, 07:31 PM   #10
Yeah
I'm running Hot Racing trailing arms but am not sure if they would work for what you're trying to do.
BTW, I also have the Bomber so I'm curious to learn the results for your experiment with Twin Hammer trailing arms.
Old 01-03-2016, 08:25 PM   #11
Here is the start of the discussion on it. I picked up a used set of Blue Monkey Wraith length arms. Need to trade those off for some Twin Hammers ones I think. Anyone want to extend their Twin Hammers about a half an inch....? ;)
Wheelbase vs trailing arm length
Old 01-03-2016, 10:36 PM   #12
So by shortening the arms, what are you planning to run for the driveshafts?
Old 01-04-2016, 07:56 AM   #13
For now I am running the plastic axial shafts with a long and a short section. Once I go shorter yet can swap to both short sections or cut one down if needed. Once I dial it in I can try to find a MIP that will fit
Rear link lengths? - Similar Threads
Bender SWX 4-Link Link lengths PGT-RC Axial AX-10 Scorpion 0 04-16-2014 07:19 AM
link lengths? gtxr Axial XR10 1 05-21-2012 08:08 PM
4-link and link lengths questions T DAWGv12 Axial SCX-10 5 11-27-2010 11:17 AM
upper link lengths for SCX10 with stock four link oscodawave Axial SCX-10 4 11-19-2010 08:23 PM
Looking for link lengths for 4 link on the Honcho Skeeno Axial SCX-10 5 12-20-2009 08:34 PM
