03-07-2016, 11:51 AM | #1 |
Newbie Join Date: Mar 2016 Location: Yuma, Az.
| Dick Dragon's Scale Hammer build
I have a TH on the way and I have a few goodies waiting for its arrival....so I thought I would start with the scale accessories and then update as parts and the vehicle show up. Here are a few trail tools I built ready to go... Directly from the White House to you.... |
03-07-2016, 11:56 AM | #2 |
| Re: Dick Dragon's Scale Hammer build
Some safety cones.... I used yellow wire nuts mounted to styrene plates.... drilled the tops out and painted them safety orange..... The machete in the last pic is made from Styrene also Much more to come! Directly from the White House to you.... |
03-07-2016, 11:59 AM | #3 |
The Faux Warn winch was the most complicated... But I think it turned out OK.... Not sure I'm going to use this, I may go with an operational unit. But it sure was a fun build! Directly from the White House to you.... |
03-07-2016, 12:02 PM | #4 |
Fuel cell build...may hide the winch ESC there... Not complete yet, still have to build the fill, but going to wait until fitment in car.... Directly from the White House to you.... |
03-07-2016, 12:06 PM | #5 |
Rock Crawler Join Date: Jul 2005 Location: Playing with toys with my son's
Looking good, like seeing more and more people going scale with the hammer. It can do it all |
03-07-2016, 12:07 PM | #6 |
Doing a trailer build also...will update more when I get a little further and more pix.... I made the fire extinguisher also...did not get as many pix as I should.. The hand saw is hand made also Directly from the White House to you.... |
03-07-2016, 02:42 PM | #7 |
Thanks, can't wait for the car to get here!
03-08-2016, 11:33 AM | #8 |
After all the research I've done so far, I have to say I'm really disappointed in a lot of the aftermarket parts! Not that some of them are not great parts, they just don't fit the scale aspect! Looks like I'll be using, building my own front upright shock mounts as well as many other parts, to try and keep in the scale realm of this build. I will say tho, the Sr.Irie steering kit is definitely going to be one that goes on my car.... the reviews and the quality of that kit are just by far the best I can find out there! So this build may take a little longer than I had anticipated, but making my own parts should really add to the realism and scale aspect of this build..... I hope I can live up to some of the other builds on this forum! NOW WHERE IS THAT PESKY FED-EX TRUCK? Last edited by Dick Dragon; 03-08-2016 at 12:20 PM. |
03-08-2016, 12:33 PM | #9 | |
| Re: Dick Dragon's Scale Hammer build Quote:
The old tester installed Yet another formula for testing | |
03-08-2016, 12:40 PM | #10 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
03-08-2016, 12:42 PM | #11 |
Will do and thanks for the support, much appreciated! Directly from the White House to you.... |
03-08-2016, 01:42 PM | #12 |
| Re: Dick Dragon's Scale Hammer build |
03-08-2016, 07:10 PM | #13 |
Woo-whoo it was here when I got home! Already in pieces,lol! Can't stand the fake plastic chrome, so stripped the wheels and tires down first....painted the wheels as close as I could get to gun metal grey and then started with chrome silver and then Fluorescent green on the bead rings...Going for an anodized green look and think it came out pretty close..... I had a couple disc brake hexes left from a drifter build, going to run those until I get the aluminum hexes.... Last edited by Dick Dragon; 03-08-2016 at 07:12 PM. |
03-08-2016, 07:21 PM | #14 |
And then modded the rear link mount on the pumkin... I cut the shoulders of the stock link mount....it moved the links 5.50mm closer together... And then added some Losi kingpin sleeves under the link mount which raised it 5.68mm Also added SS hardware... I am also going to make new upper links 5mm longer that stock to improve the drive shaft angle.. I did see what everyone is complaining about the soft Hardware, I don't think it's necessarily the hardware.....what I found was instead of using metric hex wrenches & I started using SAE's and have not had an issue again after that. Directly from the White House to you.... Last edited by Dick Dragon; 03-08-2016 at 07:23 PM. |
03-08-2016, 07:32 PM | #15 |
I am going to use the shocks off of a Losi Ten-SCTE the rear shocks are 100mm long, so I added longer rod ends and they now set a 104mm.... Also added SS hardware here too. The Losi fronts are 85mm long, so I'm going to use them as is. I just need to fab up the upright shock mounts. Directly from the White House to you.... Last edited by Dick Dragon; 03-08-2016 at 07:45 PM. |
03-08-2016, 07:39 PM | #16 |
I had a roof panel left over from a Wraith build I did a while back, so used that for the roof panel and the number plates... I made a quick release wing mount for the spare and moved it forward.... Directly from the White House to you.... Last edited by Dick Dragon; 03-08-2016 at 07:47 PM. |
03-09-2016, 07:36 AM | #17 |
Added an old KO PROPO PDS-2368 ICS, I found in the parts pile for steering. I will swap this for a 300+ oz. Torgue servo later and convert this one to a winch servo... Going to run it off a Castle BEC @ 6.5v..may push it to 6.8 and see what temps I have. For ESC, running a Castle MMP, with a Flash 3400kv. Motor.... Starting @ 21t pinion with stock Spur...will play around with larger spurs later... I want to mount it & the BEC in the stock batt. location and receiver in the stock fr. shock location....more to come on the battery location.... Directly from the White House to you.... Last edited by Dick Dragon; 03-14-2016 at 09:27 AM. |
03-10-2016, 10:08 PM | #18 |
I got a chance to knock out a couple more items.... GPS, oil cooler, new head, painted helmet & mounted battery, beer can.... Also made rear panel and tail lights.... Directly from the White House to you.... Last edited by Dick Dragon; 03-11-2016 at 01:11 AM. |
03-10-2016, 10:44 PM | #19 |
Mounted ESC and new shift servo... Decided to leave the battery in the stock location.. Also got the front shock mount made and mounted.... I could only find one Losi soft spring....good thing I have a new set on the way,lol! Directly from the White House to you.... |
03-10-2016, 10:59 PM | #20 |
Found a couple more little goodies in the Crawler box o' parts..... Directly from the White House to you.... |
Dick Dragon's Scale Hammer build - Similar Threads | ||||
dragon's expedition biuld | dragon | 1.9 Scale Rigs | 2 | 08-21-2011 07:36 PM |
Dragon's bully... | taehyung kwon | RC4WD Bully | 9 | 06-23-2011 10:29 PM |
RC4WD Dick Cepek 1.9 Mud Country Scale Tires | RPP Hobby | RPP Hobby | 5 | 08-27-2010 03:32 PM |
