07-27-2016, 04:55 AM | #1 |
Newbie Join Date: Dec 2015 Location: UK
| Twin hammers gearing question
I have a brushed 35t motor and need to know the best gearing for it to use mainly for crawling but also give it a little speed when needed? Currently looking at the Robinsons hardened spur gears with either 78T or 87T but which size pinion should I be looking for? Not going to use brushless motor so please dont recommend a change to this.
07-31-2016, 12:21 AM | #2 |
Rock Stacker Join Date: May 2015 Location: North Lakes, QLD
| Re: Twin hammers gearing question R/C Calculations Twin Hammers Gear Chart Using those two you can work things backward from the top speed you are after. I have a 35t pinion but you can't fit the spur cover on if you use it. 27t + 78t spur is probably a good fit for your high turn motor. 2s or 3s? |
08-01-2016, 07:28 AM | #3 |
If you mainly want to crawl then I'd try a 25 tooth pinion to start. This should give you plenty of crawlibility with a 35T. If you need more speed then step up to a 27 or 28.
Twin hammers gearing question - Similar Threads | ||||
Twin hammers screw question | Andyking | Vaterra Twin Hammers | 1 | 04-29-2014 09:46 AM |
3s twin hammers-BRXL-13t gearing | Hoser1869 | Vaterra Twin Hammers | 2 | 12-07-2013 12:32 PM |
HH 13t twin hammer Ed gearing question | robvbro81 | Vaterra Twin Hammers | 6 | 06-03-2013 06:24 PM |
gearing with vxl on twin hammers | tmaxxdout | Vaterra Twin Hammers | 0 | 04-29-2013 12:12 PM |
