02-04-2017, 10:13 AM | #1 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| Any zero Ackerman knuckle options?
I've done a fair amount of searching and can't find anything. I've never liked the steering geometry. Any leads would be appreciated. Last edited by jebster; 02-04-2017 at 10:31 AM. |
02-04-2017, 10:26 AM | #2 |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
| Re: Any zero Ackerman knuckle options?
Hi. The outside wheel should be turned less, since it is rolling around a wider radius than the inside wheel. The ackerman of the hammers is spot on in this regard. Its where you have front set steering arms = negative ackerman (wraith for instance) that it is a problem, and zero ackerman knuckles are desirable.
02-04-2017, 11:17 AM | #3 | |
| Re: Any zero Ackerman knuckle options? Quote:
02-05-2017, 02:54 PM | #4 |
Newbie Join Date: Aug 2015 Location: Novara
There are other ways to compensate the TH lack of steering, one is the mod kit to turn the two speed trasmission into an underdrove for the rear wich you can turn on and off
Any zero Ackerman knuckle options? - Similar Threads | ||||
Zero Ackerman Knuckle Arm question | desertdude | G-Made Sawback | 2 | 12-20-2015 11:14 AM |
BWD Zero Ackerman knuckle modification | kurt | Losi Mini-Rock Crawler | 15 | 10-06-2010 05:51 AM |
