Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: 2-speed vs locked vs scx10
Old 02-04-2017, 08:32 PM   #1
Default 2-speed vs locked vs scx10
Hi, I'm new to crawlers but have 5 other rc trucks. Anyway, picked up a used twin hammers. I've been going thru it and trying to figure out a build plan. Will be used for trailing on hiking paths, etc., mostly dirt. Ain't a whole lot of rocks in South Louisiana. It has a stock 2 speed tranny with all metal gears but no shift servo. I also only have 2 channel radios. Looking for opinions, pros/cons of staying 2 speed, locking it in high, or swapping in an scx10 trans. I have not driven it yet cause I'm waiting on other parts to get it running.
butaford is offline   Reply With Quote
Old 02-04-2017, 08:40 PM   #2
Default Re: 2-speed vs locked vs scx10
If your not crawling then I would go with an scx trans with metal gears. If your not crawling then 2 speed is really pointless unless you just like the novelty of it. And an scx trans is better than a locked vaterra trans because it is lighter and has less slop then the vaterra trans.
Sent from my SM-G920T using Tapatalk
Di_Spencer is offline   Reply With Quote
Old 02-04-2017, 08:44 PM   #3
If do the scx trans you should use this adapter plate to mount it. I use it and it works and fits great. https://www.shapeways.com/product/NN...ionId=57414858
Old 02-04-2017, 09:56 PM   #4
I would keep the 2 speed then you can do both, there is a manual shift lever on shapways as well.
Twin Hammers Manual Gear Change Lever
Sr.Irie is offline   Reply With Quote
Old 02-04-2017, 10:40 PM   #5
Originally Posted by butaford View Post
Any pics of this setup? I'm not having any luck finding any.
Stout rc used to make a mount that was on shapeways.
onecool54@yahoo is offline   Reply With Quote
Old 02-04-2017, 11:18 PM   #6
Yeah thats the shapeways link I put in a couple posts up. You can still order it from Shapeways.
Old 02-04-2017, 11:25 PM   #7
The 2 speed transmission will allow you more versatility over the long run, should you keep your Twin Hammers for a while.
The Twin Hammers really can do both, high speed bashing and low speed crawling. If you ever decide to build your Twin Hammers into a crawler, you'll already have the transmission set-up to do it by just switching into low gear.
You never know, you might move to a location with rocks, you might decide to go on vacation in a rocky location, or President Trump might ship a bunch of rocks out to Louisiana...
Fallen is offline   Reply With Quote
Old 02-05-2017, 10:18 AM   #8
Well if they send rocks down here they probably gonna get dumped in the gulf of Mexico. I guess I could get lucky and they would put them on dry land.
Old 02-05-2017, 03:24 PM   #9
Will the 2 speed stay locked by itself if I manually do it?
Old 02-05-2017, 06:44 PM   #10
There are a couple of ways you can permanently lock the gearbox in high or low gear, but what I've done with mine is simply made a manual shifter to shift between gears. Just poke my finger through the cage and change the gear as required. Very occasionally it jumps out of gear, but most of the time there isn't an issue. Looks like a scale gear stick also.
Rotare is offline   Reply With Quote
Old 02-06-2017, 01:07 AM   #11
For the 2 speed transmission to remain in one of the gears (high or low) of your choosing, you'll need some mechanical means of holding it there. Many (including me) use a turnbuckle to do this. Some use a dead servo, or you can be creative (as pictured above) and fab up some other means of holding the transmission in gear.
Without some mechanical means, the 2 speed transmission will not stay in either gear, but will continually slip into neutral.
Old 02-06-2017, 06:14 AM   #12
Dbx
The Scorched Parts manual change has a sprung loaded latch on the lever to keep it in gear.... costs less than a servo too:
Dbx is offline   Reply With Quote
Old 02-06-2017, 12:27 PM   #13
That Scorched Parts gear change lever is the best option on the market in my opinion.
My whole build is set up for crawling only, so I'd never be changing back and forth between gears on a run. But having the ability to change gears in case my build goes in a different direction...that's sweet.
And since I never change gears while running, having to remove the cage in order to change gears doesn't concern me. If I'd be changing gears, that's because the vehicle is being built differently, so the cage is coming off anyway.
Old 02-06-2017, 12:42 PM   #14
I think I'll try the scorched parts manual switch for now and just see what direction the build goes.
Old 02-06-2017, 12:55 PM   #15
Dbx
You can operate it with the cage in place no problem, you just need to cut a decent size access hole in the interior part, or run without it.
Old 02-06-2017, 03:27 PM   #16
Slow is the new Fast
smog's Avatar
Personally I locked into high and chose to run a brushless sensored setup. With a smooth slow start up and good hi end speed, there is no need for low gear.
smog is offline   Reply With Quote
Old 02-06-2017, 06:46 PM   #17
I want to look into brushless also. It came with an ax5 esc and a 35turn brushed motor. Just need to fix front diff and get some wheels and tires.
Old 02-06-2017, 08:34 PM   #18
Rotare you got any more pics of your chassis/electronics layout?
Sure - there's plenty of details in this thread I created of the mods I've done.
Rotare' twin hammer - on the cheap
Old 02-18-2017, 08:32 PM   #19
Anybody know what a scx10 trans correspond to? First gear, second gear, or something in between?
dbuus is offline   Reply With Quote
Old 02-20-2017, 08:25 AM   #20
My records show the SCX10 trans ratio is 2.6:1. The Twin Hammers is 4.05:1 Low, and 2.27:1 High.
jgrim is offline   Reply With Quote
2-speed vs locked vs scx10 - Similar Threads
Locked Up's SCX10 II Build Locked Up Axial SCX10 II 120 12-07-2018 08:36 AM
Locked R3 single speed ? Tad RC4WD Trail Finder 2 3 04-02-2016 01:33 PM
