03-24-2017, 12:29 AM | #1 |
Quarry Creeper Join Date: Mar 2017 Location: San Diego
| Possible to gear down only the low speed?
Hey all, So I am fairly new to the RC hobby, and have been reading (here Simple Guide to RC Gearing – Radio Control Tips) up on how gearing works, how motors work, etc. I understand that to make my rig slower I want a (tooth count) smaller pinion gear or larger spur gear, and I understand lower turn motors are faster than higher turn motors. My question is specifically about the 2-speed transmission in the TH. Is is possible to change individual gear sets? IE. Swap out the "low" speed spur gear with a much higher tooth count to gear my TH way down for crawling in the "low" gear, while maintaining the speed of the "high" speed? |
03-24-2017, 08:33 AM | #2 |
Pebble Pounder Join Date: Dec 2011 Location: Ridgecrest, CA
| Re: Possible to gear down only the low speed?
To my knowledge there are no optional gear sets available for the TW transmission.
03-24-2017, 05:36 PM | #3 |
Rock Stacker Join Date: Jan 2017 Location: Adelaide
Not that I'm aware of either but I haven't actually looked. Are you using the stock 15t brushed motor? With the stock motor I got best results with a 24 tooth pinion but it wasn't that quick in high. The stock motor lacks torque so you need to gear for either speed or crawling but the 2 speed allows fair performance for both. Brushless is the answer if you want everything Last edited by SkiSteve; 03-24-2017 at 05:47 PM. |
03-24-2017, 06:08 PM | #4 | |
| Re: Possible to gear down only the low speed? Quote:
03-25-2017, 05:00 PM | #5 |
I think your best bet for all round performance would be to go 3s with a compatible motor and gear down. You'll struggle for speed on 2s without over gearing
Possible to gear down only the low speed? - Similar Threads | ||||
Axial 48P 2-Speed Low Gear (18T) | mark32 | Axial Yeti | 3 | 01-03-2015 10:33 PM |
Low..Low gear Mod for 1/18th | vader | General Crawlers | 3 | 04-06-2006 06:43 AM |
the low down on the xtra low gear mod | heeper40 | General Crawlers | 9 | 02-02-2006 12:35 PM |
