Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Perfect twin hammers roof led light bar
Old 09-03-2017, 09:52 PM   #1
Default Perfect twin hammers roof led light bar
Just received a new 6 led 102mm light bar from Power Hobby and I just thought I would share how perfectly it fits the twin hammers!!
If you can see from the pictures, the light bar tabs are the perfect width to use the front side screws which hold the cage together. All I had to do was trim 1mm off each end of the cross tube which means I lost the outermost roof screw hole, but I wasn't using it.
As you can see mine is mounted underneath the roof for protection but this mounting method works on top as well. Very low profile!
Bar light performance is very good on 6v.
Sent from my Pixel using Tapatalk
nedmo is offline   Reply With Quote
