Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Electronics
Thread: Tziworld Beefy Winch Controller - Now With Video!!!
Old 12-22-2011, 08:52 AM   #1
Tzi
Default Tziworld Beefy Winch Controller - Now With Video!!!
Tziworld
'Beefy Winch Controller'
Give your winch some more grunt!
Replace your weak winch controller with one of these custom made winch controllers.
Equipped with 2x relays, this winch controller will handle up to a massive 32volts, and is capable of running even the biggest baddest servo winch!
With a passive electronic brake your winch will not rapidly spool out when under load and the winch will stop instantly rather than winding down slowly when you release the switch on your transmitter.
This controller independently switches DC power from a separate supply which means you can run a seperate 3cell (or more) battery for your winch to give it some more grunt!
NEW VIDEO - Servo load testing with the Tziworld Beefy Winch Controller Part 1
NEW VIDEO - Servo load testing with the Tziworld Beefy Winch Controller Part 2
Pricing:
Normally $50AU, currently on introductory special for $45AU
Postage within Australia - $5
International Postage - about $11
Beefy Winch Controller in $AU
Beefy Winch Controller in $USD
Tzi is offline   Reply With Quote
Old 12-26-2011, 03:39 AM   #2
Default Re: Tziworld Beefy Winch Controller
Have given one of these things a work out, top controller.
sierrajim is offline   Reply With Quote
Old 02-07-2012, 09:21 PM   #3
Tzi
Currently out of stock, but I hope to have more in shortly. Thanks for the orders guys!
One thing to note... please send me a PM before ordering as international shipping can be lowered to $5 instead of $11, but my shopping cart will not allow it on the customer side.
Old 02-15-2012, 06:20 AM   #4
Tzi
Here's a video of some testing I did this weekend to show how the controller works while I was testing a winch.
Tziworld - Servo Winch Test - YouTube
Old 02-15-2012, 12:31 PM   #5
Great video Jyi and I'm very impressed with your controller.
Don't suppose I can talk you into a repeat performance when your 8274 arrives...
I just got the controller you sent me for the give-away winch and look forward to doing some testing myself, but I don't have the cool electronic gismos you do.
Maybe I'll see if I can bug Chris, and help him with his next installment in the QS tech thread using the controller you sent.
Nice work on a great product.
QUICKSAND is offline   Reply With Quote
Old 02-25-2012, 09:44 PM   #6
Default Re: Tziworld Beefy Winch Controller - Now With Video!!!
Dang Jyi....easy on the winch spools! Glad to see how much torque they can withstand. That's an amazing difference between the stock board and your controller. Can't wait to see what kind of numbers you can get with the 8274. I accidently spooled in when I should have spooled out at the last scale comp we had. Your controller with the 8274 on 3s and it snapped my 130lb line like it was nothing. Can't wait to see what your scale says.....
War Pig is offline   Reply With Quote
Old 02-26-2012, 12:23 AM   #7
Tzi
My 8274 arrived late last week, but I'm off on holidays tomorrow so no time for testing.
I've tested two more servos since that video and will add a new video up soon.
Got more winch controllers on the way, and some even have a soft-startup option too which sounds absolutely wickid as it winds up.
I'm not sure what line to use, or how far the 8274 is going to go before stall, but I suspect my digital scales will say something along the lines of "BANG" haha... time to find a 100kg scale I think
Old 02-26-2012, 01:21 PM   #8
Moderator Rule Breaker
eric113's Avatar
How this for test pull ?
eric113 is offline   Reply With Quote
Old 03-02-2012, 11:54 AM   #9
Holmes Hobbies
CD13's Avatar
PM sent, Thank You
CD13 is offline   Reply With Quote
Old 03-06-2012, 07:50 PM   #10
When will these be back in stock?
CoreyHall is offline   Reply With Quote
Old 03-07-2012, 12:31 AM   #11
Tzi
Hopefully back in stock next week.
Sorry for the slow replies to PM, but I am on vacation until wed15th
Old 03-16-2012, 10:05 PM   #12
Oppan Gangnam Style
chino63's Avatar
I'm interested in a couple, PM on it's way.
chino63 is offline   Reply With Quote
Old 03-18-2012, 07:01 PM   #13
Tzi
I recently received a limited amount of winch controllers from my manufacturer, however they are almost all gone to pre-orders.
I'll make up a pre-order list shortly, and reply to those who have already contacted me so everyone stays in order to be fair while waiting for the next batch to arrive.
Also note, winch can be custom-ordered for a two-position switch if you require. Single press to reel out, double-press to reel in.
Old 03-28-2012, 10:39 AM   #14
Holmes Hobbies
CD13's Avatar
Just checking to see if I'm on your list. I haven't recieved a message.
Old 03-28-2012, 06:02 PM   #15
Tzi
Sorry, I have been a bit slack this last week and have not got back to people. Yes, I got your PM.
I should have stock after easter.
Does anyone have a problem if I just make a list of usernames in this thread who has contacted me to order one? or should it remain private?
Old 03-29-2012, 06:55 AM   #16
Holmes Hobbies
CD13's Avatar
I don't have a problem making a list. Don't think anyone else would mind. It's not like your posting personal info and everyone would know when they are up next.
Old 03-29-2012, 01:49 PM   #17
I would like a list and you could add my name to it ...
vader2728 is offline   Reply With Quote
Old 03-30-2012, 08:14 PM   #18
Tzi
List has been posted up... please contact me if you would like to change the quantity, or you would like to be added to the list.
Stock should arrive in the next week or so, and three options will be available...
Standard -
  • Designed for those with a spare channel using a 3-position momentary switch.
  • Simple ON/OFF, no bells and whistles... it just works.
Soft Start -
  • Soft startup is easier on the gears in your winch and will gradually ramp up to speed, however it is slightly slower to stop once you let go of the
Two-Position channel -
  • Designed for those with a spare channel using a 2-position momentary
    switch. Press down for reel-out, and double press for reel-in
Other options may be available in the future...
Old 03-31-2012, 06:34 AM   #19
Tzi
.... Just added a new video with further servo testing ;)
Tziworld - Servo Winch Test 2 - YouTube
Old 03-31-2012, 07:44 PM   #20
Where's the Quicksand winch test you promised us? I want to see some carnage .
Tziworld Beefy Winch Controller - Now With Video!!! - Similar Threads
Winch Controller-How much amps does a winch pull losikid Electronics 3 02-27-2011 04:15 PM
2 winch controller Superclass Electronics 1 09-30-2010 05:15 AM
Winch controller ???? braceysdad Electronics 0 09-18-2008 07:15 PM
You may edit your posts
