01-13-2012, 05:44 PM | #1 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
| Team Brood Intensity Machine Wounds
Proud to introduce are newest machine wound motor the Intensity. Currently available in 19t,25t,30t,35t and 45t. These feature standup brushes, powerful C6 wet magnets, 4.6mm web machine wound armature with 7.5mm comm, ball bearings, adjustable timing, and more. 35t and 45t is available in matched pairs. Intensity, Team Brood Racing Later EddieO Last edited by EddieO; 07-08-2012 at 07:02 PM. |
05-06-2012, 12:09 AM | #2 |
| Re: Team Brood Intensity Machine Wounds
New winds available in these......25t and 30t for the Scaler crowd, while 45t for the MOA crowd. Later EddieO |
06-04-2012, 09:28 AM | #3 |
Newbie Join Date: May 2012 Location: yakima
hey eddie, can the intensity be had with lower turns like 15 thru 19turn?
06-05-2012, 12:37 AM | #4 |
19t is available on the site.......lower winds from me are not available, though trinity sells them under their speed gem line if you really want one. If you PM me, I can just cut you a deal on a handwound arm though in 7-14t pretty easy for the same price.... Later EddieO |
07-05-2012, 12:36 PM | #5 |
Quarry Creeper Join Date: Apr 2012 Location: Talladega, AL
EddieO. Here are those motors I was asking about. Sent from my Razr from the deepest part of your brain using tapatalk |
07-05-2012, 01:30 PM | #6 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
link no worky...
07-08-2012, 05:57 PM | #7 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| Re: Team Brood Intensity Machine Wounds |
07-08-2012, 07:03 PM | #8 |
New website killed all the links in these product threads....its updated now. In stock and shipping! Later EddieO |
07-13-2012, 06:47 PM | #9 |
Rock Crawler Join Date: Mar 2011 Location: hampton
just ordered mine looking forward to stepping up from my integy 35t |
08-16-2012, 11:53 AM | #10 |
Pebble Pounder Join Date: Nov 2010 Location: citrus hts
hey eddie i jus got my 19t the other day broke it n yesterday on 2s, i ran 3s on it today for about 10 mins motor got real hot, is that normal for 3s, was doin couple curb jumps and high speed runs, jus makin sure it can handle 3s
08-16-2012, 12:26 PM | #11 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: Team Brood Intensity Machine Wounds Did you gear down? You don't just add volts and keep the same gearing. That can cause motor failure due to extreme heat.
08-16-2012, 01:16 PM | #12 |
| Re: Team Brood Intensity Machine Wounds no use n 87 spur and 23 pinion, thats whut i was runin with my HH 35t, i normally run 3s all the time, but was jus breakn in on 2s, whut gearing should i run? i went to this motor for more speed
08-16-2012, 04:34 PM | #13 |
| Re: Team Brood Intensity Machine Wounds jus did a crawlin run and got hella hot, so went to lhs and got a 18t and 16t pinion
08-16-2012, 05:08 PM | #14 |
A 19t from a 35t is a MASSIVE difference in gearing. In the Wraiths guys will typically gear them like 13/87..... When switching from 2s to 3s, requires additional gearing changes....a 35t is a pretty tame motor, so potential damage isn't as big. A good 35t will make 110+ watts on the dyno (at crawler testing)....a 19t will be over 180... The motor can handle 3s no problem, but gearing has to be correct, which is true with any motor. All team brood motors come broken in....... Later EddieO |
08-16-2012, 05:15 PM | #15 | |
| Re: Team Brood Intensity Machine Wounds Quote:
ok kool so u reccomend goin lower then 16t? or whut do u reccomend eddie??? | |
08-16-2012, 05:26 PM | #16 |
I'd try a 13t first and monitor temps. Later EddieO |
08-16-2012, 06:07 PM | #17 |
08-27-2012, 02:07 PM | #18 |
Rock Crawler Join Date: Nov 2008 Location: The Lone Star State
Team Brood Intensity Machine Wounds - Similar Threads | ||||
Team Brood Ravage Machine Wound Motors | EddieO | Vendors Electronics | 4 | 10-31-2011 08:19 PM |
Team Brood motors... got 'em! | kineteks | General Crawlers | 0 | 04-23-2009 10:36 AM |
