09-01-2014, 01:57 AM | #1 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
| Team Brood Trail Limited Edition 35 Turn 2014 #1
A new one for you trail monsters...These bad boys use the Reedy Stockstar endbell and can. - Six-Sided Diamond Shaped Brushes, the unique laydown design and orientation optimizes brush wrap around the commutator and creates a better firing pulse to the armature. Their diamond shape locks them in place inside the brush tube resulting in reduced vibration, increased RPM, and more power. - Extra Long Brush Tubes housed in an exclusive endbell increase brush support resulting in less vibration, maximum RPM, higher power output, and extended brush and commutator life. Silver plating reduces resistance and allows current flow through multiple paths - Silver Plated Brush Hoods reduce resistance and ensure easy soldering of ESC wires and brush shunts. - High Temperature Coil Brush Springs maintain the desired brush/commutator connection even under the most demanding loads. Spring retainers have been color coded for polarity and make brush and spring changes easier than ever - FB9 Wet Magnets resist heat and fade, and have a long lifespan - Surface Mount Capacitors come pre-installed to reduce interference - Low Friction Bushings to resist the elements that leads to premature failure in ball bearings This Limited Edition Features a slotted armature. Years ago, Marc Rheinard used an armature like this to win the Touring Car World Championships. The slot in the arm basically frees up the arm as it rotates through the magnetic field. In crawling it will mimick a 4 magnet can to a degree, but you won't lose as much drag brake as you do with a 4 magnet can....since the arm has less steel, there is a little loss of torque, but they produce more overall power. Wound with a high efficiency 35 turn wind to maximize battery life while still providing good power and crawling performance. Also, having gone over Epoxy Balancing before, these are Epoxy balanced so we are NOT removing any more steel, as with the slot a decent amount has been removed already. Only 6 Motors are being made...6 lucky souls. Shaft is engraved with wind. Limited Edition Sticker Here are the specs 2 Magnet High Torque Can Diamond Brushes 5mm Slotted Armature Epoxy Balanced 7.5mm Comm 35 Turns of 21 AWG Wire $84.99 plus Shipping $7 shipping in the USA (international rates vary)......First come first served! Order Here! Team Brood Racing LE Trail Motor Last edited by EddieO; 09-01-2014 at 01:59 AM. |
Team Brood Trail Limited Edition 35 Turn 2014 #1 - Similar Threads | ||||
Team Brood Scaler Limited Edition 35 Turn 2014 #2 | EddieO | Vendors Electronics | 3 | 07-29-2014 11:11 AM |
Team Brood 2014 Limited Edition Scaler Motor | EddieO | Vendors Electronics | 5 | 06-01-2014 04:54 PM |
Team Brood Scaler V2 Limited Edition 35 Turn Epoxy Balanced HHK Slotted Armature!!! | EddieO | Vendors Electronics | 9 | 07-01-2013 01:31 PM |
