07-14-2007, 07:17 AM | #1 |
| Axial AX10 Scorpion at The Crawler Store - $238.99 -Features- Complete competition ready kit All new axles that feature an improved driveshaft angle and castor as well as class leading steering throw Aluminum Chassis plates with a molded nylon skid plate Ultra compact and lightweight transmission Full time locked four wheel drive Full Ball bearings Overall gear ratio range from 15:1 to 74:1 Transmission: 2.6:1; center mounted Differentials: Locked style (spool) Transmission: Single-speed Tires: Axial 2.2 Rock Lizards Wheels: Axial 2.2 Rockster Beadlocks Suspension: 3 Link Driveshafts: Universal front and rear -Chassis- Wheelbase: 304mm~320mm (12”~12.6”) Width: 254mm (10”) Height: 156mm (6.125”) Weight: 1588g (3.5 lbs) Articulation: 70° Ground Clearance: 79mm (3.125”) -Body- Length: 438mm (17.25”) Width: 181mm (7.125”) Height: 133mm (5.25”) -Axles- The axles have been designed with many features that are not available from other choices on the market. Everything from the axle strength, pinion angle, caster, and ground clearance were taken into consideration, the result is a stronger better axle that will last. An aluminum diff locker is included along with hardened drive shafts and axles. -Chassis- The AX10 Scorpion chassis is lightweight and stiff. Twin 2.0mm aluminum side plates are tied together with aluminum posts and a molded nylon skid plate/transmission plate. The chassis was made as small and compact as possible to cut weight as much as possible. A simple battery/radio tray makes installation of your electronics quick and easy. Wheel base is adjustable from 304mm ~ 320mm. -Transmission- The AX10 Scorpion transmission was designed to place the weight of the motor as low as possible while still allowing a wide range of gearing choices. The overall ratio can be adjusted from 15:1 all the way up to 74:1 using different pinion/spur gear choices. The transmission is locked with no differential action and features hard anodized aluminum out-drive shafts. -Shocks, Links and Driveshafts- Super long shocks offer a wider range of articulation as well as an optional range of spring choices so you can tune your crawler to work on any terrain. All suspension links are made from lightweight and strong aluminum. The driveshaft is made from super strong composite material and features hardened metal yokes. -Wheels, Tires and Body- No crawler would be complete without the essentials. The AX10 Scorpion will be outfitted with the popular 2.2 Rockster beadlocks sporting green rock rings and Rock Lizard tires. Also included is the popular B-17 Betty body in .040” thick polycarbonate. http://www.axialracing.com/ftp/Press...04-07/AX10.htm Pre-order for $238.99 This is a pre-order item. These will ship to you when they come in stock. www.tcscrawlers.com |
07-14-2007, 03:12 PM | #2 |
Quarry Creeper Join Date: Oct 2006 Location: Japan
Great price, sorry to ask the most obviously dumb question but would you have a timeframe as to when they will be instock and be shipped? Can't wait! Also the Axial Rock Lizards you have in stock, are they the new version? Cheers in advance, genki |
07-14-2007, 08:28 PM | #3 |
Cool, after I see how these hold up, I might get one for my boy! |
07-14-2007, 09:12 PM | #4 |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
Payment options? Shipping cost?
07-15-2007, 04:34 PM | #5 |
07-26-2007, 01:48 PM | #6 |
Rock Stacker Join Date: Jul 2007 Location: Sweden
can´t wait to get my hands on the AX10 |
07-26-2007, 02:04 PM | #7 |
Pebble Pounder Join Date: May 2006 Location: fremont
hmmm il already see aleaf mounting location the axles i might have to pick one of these up
08-01-2007, 10:01 PM | #8 |
Rock Crawler Join Date: Aug 2006 Location: On the trail
when are you going to sell just the tranny or just the axles?? thanks |
08-01-2007, 10:06 PM | #9 | |
http://www.tcscrawlers.com/home.php?cat=254 | |
08-02-2007, 04:40 AM | #10 | |
Thanks! | |
08-20-2007, 03:37 AM | #11 |
Newbie Join Date: Sep 2006 Location: Down underrrr
Are they being posted out yet?
