Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Tires and wheels
Thread: 2.2 Wheel Wideners!
Old 12-05-2014, 02:23 PM   #1
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Default 2.2 Wheel Wideners!
A lot of you contacted us about having these made so we are thrilled to now offer them!
Our 2.2 Wheel wideners are sold in pairs and will allow you to add just over 7mm to the face of your 2.2 Wheels. The wideners will work with any LURC 2.2 wheel (even the older non easy mount styles) and any 2.2 wheel based on the Axial 2.2 AX10 bead lock ring pattern.
To make use of the wideners you will need to run M2x14 screws or scale hex bolts.
These can be used on the outside or inside (clearance depending) of your wheels or you can also stack these and run M2x21 screws!
Thanks for reading!
Locked Up is offline   Reply With Quote
2.2 Wheel Wideners! - Similar Threads
Wheel wideners rocksteadily Tamiya TLT Crawlers 1 11-24-2011 09:55 PM
Wheel wideners / wheel adapters? AXLE 69 Tamiya Txt-1 and Juggernaut 1 03-16-2009 09:22 AM
You may edit your posts
