Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Tires and wheels
Thread: 3D printed Micro Crawler Rims
Old 09-26-2014, 02:10 PM   #1
Default 3D printed Micro Crawler Rims
These rims fit the Losi Trail Trekker or Losi Micro Rock Crawler rigs. Here are the rims I have to offer.
Please read this Information Page
The rims have the 7mm hex mount. The offset can be stock, 1/8" or 1/4". An 1/8" offset rim on McRC axles will make the width the same as a Trail Trekker with stock rims.
The weight recess is a groove for adding factory weights, or wrapping copper wire, but there are rims without this recess for a more scale appearance.
Some rims will require you to modify a lug nut tool so it will fit inside the small hole. I chucked it in a drill press and used a file to slim it down to fit.
I have made the rims available on my Shapeways Shop. They're available in durable Strong and Flexible sintered nylon, or Frosted Detail acrylic. The nylon is more rugged and is cheaper, but the finish is not as smooth. The high detail acrylic offers stunningly intricate details but with a higher cost. Here is a comparison of a typical rim, nylon on the left and acrylic on the right.
Here are some images of painted Frosted Detail acrylic rims.
Fungi is offline   Reply With Quote
Old 09-26-2014, 02:28 PM   #2
Default Re: 3D printed Micro Crawler Rims
Look pretty good. Maybe a dumb question, but what wheel diameter are these shown? Or can be whatever size needed?
Szczerba is offline   Reply With Quote
Old 09-26-2014, 02:44 PM   #3
I'll edit the post, they're for Losi Micro, so Trail Trekker, or MCRC. It would be cost prohibitive to do larger rims.
Old 09-26-2014, 06:22 PM   #4
Shut up and take my money
Joeyblaze is offline   Reply With Quote
Old 09-27-2014, 05:41 AM   #5
When will these be in stock?
Thanks for the update.. PM sent
MGCrawler is offline   Reply With Quote
Old 09-27-2014, 06:13 AM   #6
Sorry I took the stock thing off, what's not in stock I can print quick enough.
Old 09-27-2014, 08:38 PM   #7
Do ya have a pic of the rear duals under a truck?
malofish is offline   Reply With Quote
Old 09-28-2014, 06:59 AM   #8
Here are a few images.
Old 10-01-2014, 12:06 AM   #9
Do the tires have to be glued or can you do anything with a beadlock?
grandbolin is offline   Reply With Quote
Old 10-01-2014, 08:15 AM   #10
I'ts practically impossible to make a scale beadlock, because the screws are so large. These rims require gluing the tires on. I may eventually try making some beadlocks though.
Old 10-02-2014, 09:16 PM   #11
I received my wheel order in the mail a day or two ago, Thanks Jim! Very nice product and speedy shipping
Old 10-04-2014, 12:00 AM   #12
Same here. Beautiful rims!
stopmojim is offline   Reply With Quote
Old 10-07-2014, 12:18 PM   #13
Here's some more pictures.
Old 10-07-2014, 04:59 PM   #14
Can you make the wagon wheel style with a functional bead lock?
Old 10-08-2014, 07:07 AM   #15
I'll give it a try.
Old 10-09-2014, 12:14 PM   #16
How wide are the dually rims? I'm wondering if they could be used with a wider tire such as a cut-down paddle tire from a mini-t.
R.Billy Rob is offline   Reply With Quote
Old 10-12-2014, 10:39 PM   #17
I would love to have a set of the wagon wheel style if you could get it in a bead lock. I under stand though with the screws being to big to look scale though. Let me know if you can do it.
Old 10-20-2014, 03:56 PM   #18
Hi Billy, The Dually Rim is 1.272" wide, but I can make a rim with any width you want. No need to use a dually rim for extra width. ;)
Grandbolin, I have made a true bead-lock. I am still working on trying to make a wagon wheel version. The screws from a normal rim are too short to work, the longer ones (the ones that are left over from tearing apart a Trekker frame and unnecessary parts) work well. I'm looking for a source for them. The rings are no problem for me to make. What offset are you interested in?
Old 10-21-2014, 08:24 PM   #19
These wheels are sick! Just called a coulple of buddies with micros that might buy a set of the dually rims.
josh h is offline   Reply With Quote
Old 10-21-2014, 08:33 PM   #20
Can you make bigger wheels like revo/maxx/truggy wheels?
3D printed Micro Crawler Rims - Similar Threads
BWD Micro Wheel Weight System for the new Losi Micro Crawler! billet works Vendors Market 19 10-18-2010 05:42 PM
You may edit your posts
