01-21-2009, 05:44 PM | #21 | |
Quarry Creeper Join Date: Jan 2009 Location: pacific north west
"The wheels do not come predrilled for venting the air out. This was left up to the customer so it can be tuned as needed. If you want a smaller hole for more control or if you want a larger hole for faster tire response thats up to you. I do suggest you run our wheels with some hole or you wont be taking advantage of the super soft tires and memory foam inserts. I dont suggest you make holes in the tires as this could lead to tearing and ruin the tire. Weight sets...our weight sets are precisely machined to a specific weight so a wheel can be tuned to get the desired performance. They are made from steel and are pretty accurate parts that bolt onto the wheels as a system. There have been some comments on the price of the sets, which include enough parts for 4 wheels. If you compare the price of buying a new set of machined aluminum wheels or PL plastic/alloy wheels and then tires and some weights you can see quickly that it adds up to more than one of our weight sets which are purpose built for the application. The cost of the kit and one weight set is still less than any competitors kit and a hand selected set of wheels tires and weights combined. There are no modifications to make and the parts just go together. I hope that helps shed some light on the weight sets and maybe you can see the added value of the Beadlox Wheel System. For my personal Creeper I use the 1.3 set up front for half a pound per wheel and nothing in the rear wheels. Right now that seems to be a pretty good all around set up. Chris" | |
01-21-2009, 06:11 PM | #22 |
It's still a plastic wheel w/ tiny hardware. The price of the weights is ridiculous. |
01-21-2009, 06:21 PM | #23 | ||
Ummm yeah! Quote:
01-21-2009, 08:07 PM | #24 |
Quarry Creeper Join Date: Dec 2008 Location: Punta Gorda, Flo-rida
Damn there steel too that should make them cheaper than lead, i think going down to napa auto parts and for the same price getting 5 lbs of stick on lead weights is much cheaper. I could set up 4-5 crawlers for $60 instead of one.
01-23-2009, 05:21 PM | #25 |
Quarry Creeper Join Date: Jul 2008 Location: Over a rock and under a bridge
I don't see the math and/or how they can justify it. $55.99 for weights + $19.99 for a pair of wheels + $19.99 for a pair of wheels = $95.99 for a set of wheels for a crawler. How is that better than a $100 or $110 set of aluminum wheels? Hell, I can get Eritex's $60 Delrin wheels. Seriously, $96 for plastic wheels with some fancy weights isn't what I call justifiable and reasonably priced when there are mfgs out there selling Al wheels and delrin for the same or less than these Creeper wheels. |
02-10-2009, 11:09 PM | #26 |
Newbie Join Date: Jan 2009 Location: Paradise
| http://i604.photobucket.com/albums/t...eeper007-1.jpg http://i604.photobucket.com/albums/t...creeper008.jpg http://i604.photobucket.com/albums/t...creeper009.jpg http://i604.photobucket.com/albums/t...creeper011.jpg http://i604.photobucket.com/albums/t...creeper015.jpg http://i604.photobucket.com/albums/t...creeper017.jpg Cheap and easy wheel weights |
02-11-2009, 12:41 AM | #27 |
Quarry Creeper Join Date: Dec 2008 Location: Post Falls, ID
what are those klip? hard to tell from your picture, i can make out that they are a round metalic disc with a hole, much like a washer, but what exactly?
02-11-2009, 09:25 AM | #28 |
Quarry Creeper Join Date: Dec 2008 Location: Gardnerville
02-11-2009, 06:53 PM | #29 |
Newbie Join Date: Jan 2009 Location: Milford
I went to the hardware store and found flat washers that measured 1-7/8" o.d. with a 5/8" i.d. -- 3 of them fit perfectly inside the rim under the outer bead lock ring. 3 washers = 4oz. I did this on the front and rear, plus added 1 6oz strip weight in both front tires. Seems to work well crawling around the couch. ( to much snow now, NO rocks visible at this time). |
02-11-2009, 08:22 PM | #30 |
They are steel plates that are used to cover hydraulic ports when the hose is removed, I use them at work all the time. We have a bunch in the shop so I took 4, drilled holes in the middle, and put them in the wheel. Each one weighs 8 oz. I put them in the front and rear wheels, but haven't got much time to test it. I also tried 5/8 washers but this plate fit better and weighed more. But it turns out they are not so cheap, 17 bucks a pop.
