Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Venom Creeper
Thread: Remote diff lock kit
Old 01-20-2009, 04:21 PM   #1
Default Remote diff lock kit
Who has one in stock with reasonable shipping. I just checked Tower Hobbies and they're not in stock. The Venom website shows them in stock but the shipping is outrageous. $10 plus to ship a micro servo and a few small parts. :-(
evostyle is offline   Reply With Quote
Old 01-20-2009, 07:21 PM   #2
Ultimate Hobbies had a few last time I was in there. They are located in Orange, CA.
LEADDOG is offline   Reply With Quote
Old 01-20-2009, 10:12 PM   #3
Thanks! I'll check with them.
Old 01-21-2009, 09:48 AM   #4
TCS I thought had them in stock
billysnarf is offline   Reply With Quote
Old 01-21-2009, 09:48 AM   #5
nevermind.. wrong
Old 03-30-2009, 02:13 PM   #6
Is it ok to buy one set to open / lock both differentials at the same time ?
John Doe is offline   Reply With Quote
Old 03-30-2009, 09:11 PM   #7
Nope....You need 1 set for each axle. You can probably use a Y harness to control both of them from 1 channel.
-bondo
bondo303 is offline   Reply With Quote
Old 03-31-2009, 12:54 PM   #8
thanks for the info ;)
Old 03-31-2009, 08:10 PM   #9
if i could do it again, i might just mount a servo on the axle to do that. I already have mine installed. but had to add the return spring.
I have seen a few people running an arm of some type right to the lock switch.
username is offline   Reply With Quote
Old 04-01-2009, 11:38 AM   #10
I've seen pictures of a servo mounted directly too , can't wait till everything gets here so i can start building
Old 04-01-2009, 05:51 PM   #11
... I would suggest to mount the Diff-Lock Servo directly to the steering servo and connect it with a linkage set... Works better than with the original solution...
->Pic of the mount, look here (3. pic):
Venom Tuber - many pics!
alex3773 is offline   Reply With Quote
Old 04-07-2009, 11:49 PM   #12
my son and i just got done putting his creeper together yesterday and we put the remote kit on the front and rear. in my opinion the kits are a total a waste of money. they only worked once and have never worked properly again. i need to check out the pics with the axle mounted servo it seems like a great idea compared to the orig. design. im glad i saw the last reply before i got a little nuts over the kits malfunctioning!!!!
JeepinItReal is offline   Reply With Quote
Old 04-08-2009, 07:32 AM   #13
i'll do the same, but how to prevent servo being destroy when i need to lock, coz the are 3 holes and you can hit them all the time on first servo move.
Alex
Alex.G is offline   Reply With Quote
Old 04-08-2009, 02:22 PM   #14
try doing it while your moving slowly.it should go in.
scram8 is offline   Reply With Quote
Old 04-08-2009, 03:42 PM   #15
some spring would help, but need to figure out how to add it
