Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Venom Creeper
Thread: Venom High Torque Metal Gear Servo
Old 02-04-2009, 12:49 AM   #1
Default Venom High Torque Metal Gear Servo
Anybody know what the spec's are on this servo? Part# VEN-1825
http://www.venom-group.com/itemdesc.asp?ic=VEN%2D1825
RoCk SkuLLz is offline   Reply With Quote
Old 02-04-2009, 12:58 AM   #2
Operating Voltage: 4.8-6.0V
Torque: 91.88 oz/in at 4.8V
107.20 oz/in at 6V
88_Pathy is offline   Reply With Quote
Old 02-04-2009, 11:53 AM   #3
That servo will work if you are using our crawler with no wheel weights, but the moment you go to run any wheel weights, I would highly recommend a stronger servo.
--Paul
Kootenai Krawle is offline   Reply With Quote
Old 02-04-2009, 12:55 PM   #4
Throwing Grenades
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Did I hear rumors of a new Venom servo with insane torque coming out soon?
Harley is online now   Reply With Quote
Old 02-04-2009, 02:17 PM   #5
Oh now your talkin..
Old 02-04-2009, 09:02 PM   #6
Thanks for the info. Guess i'll go with a stronger one.
Old 02-06-2009, 10:54 PM   #7
I thought this thing was supost to have 40 degres of turning radius?
I have a HItec HS-645MG on mine and it dosent seam to turn at it full potential
smashmetal is offline   Reply With Quote
Old 02-06-2009, 11:20 PM   #8
Make sure you have your EPA's at 100% and that you have a sufficiently long arm. I'm running the servo above on mine and I am getting 40 degrees out of it.
--Paul
Venom CS
Old 02-07-2009, 09:30 PM   #9
I thought that I did set the EPA's when I set it up but ill check again. Firsts RC that I have had so im still learning. The speed controler wouldent have any thing to do with it would it? I have a Tekin FX-R on it now, had I know it needed computer soft wear to really tune it I probably wouldent have gotten it.
I have been playing with the arm length but it really dosent seam to work. The directions said use a 21mm arm, I have even went slightly longer but no luck.
here is how I currently have it set up. Used and Axial 30 degree bent lower link (trimmed to fit) to make the arm. I know the hard core guys might frown on it but I though the rear mounted rod end would contact the servo and limit steering movment.
