Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Venom Creeper
Thread: Skid plate
Old 02-05-2009, 01:36 PM   #1
Default Skid plate
Hallo,
i am Oliver from Germany.
The Creeper is my first crawler. Only problem at the build was stripped threads at the 2.5mm ch screw and the thin body. It broke by drilling cuting. Have any other this problem to?
So far it is no breakage problem.
By the first run with the car, it hang with the Tranny sometimes on the ocks, so i made a skid plate. Here the prototyp:
Click the image to open in full size.Click the image to open in full size.
Sorry for my english .
Oliver
Olli23 is offline   Reply With Quote
Old 02-05-2009, 02:49 PM   #2
your english is better than my German.
I hear there will be a replacement or something similar to this coming from venom? Last I heard it was getting designed, but who knows.
Looks like nice work tho, is that a white 5 gallon bucket? or the metric equivalent over there?
username is offline   Reply With Quote
Old 02-06-2009, 01:49 AM   #3
Hallo,
it was a test and it was made of PVC. The next i will be make of Teflon.
Oliver
Old 02-06-2009, 05:19 AM   #4
#olli23 Servus aus Österreich!
Very nice idea, great work, looks good!
As soon I have build up my Venom, I will try to make a skin plate like yours...
I enjoy building up the Venom, every day a little bit after work. No problems so far, the 2,5 screws have to handeled with care... By the way, I have noticed, that the inch screwdriver fits the best to the 2,5 screws, but to the 3 screws the metric screwdriver is better...
The only abnormality so far, that the "ball joints 20 Deg" has different lenght. Some are about 1/2 - 1mm shorter than the others and the factory set screws in the rims has been overtightened...
But all in all I really enjoy building the Venom, it is really high quality and accurate made!
alex3773 is offline   Reply With Quote
Old 02-06-2009, 05:45 AM   #5
Mahlzeit Alex,
the screws in the rims are not overtightend by mine. The shorter ball joint can be the reason, that the upper rear link are a little bit shorter. I fix it with two washer, out of the set.
See you at rockcrawler.de.
Gruß Oliver
