Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Venom Creeper
Thread: Is It Bad If...
Old 02-15-2009, 10:38 PM   #1
Default Is It Bad If...
Is it bad if i run too much wheel weight? what is thh most i would want to put in each front wheel? i want to put about 6OZ. each.
Louis is offline   Reply With Quote
Old 02-15-2009, 11:07 PM   #2
vonclod's Avatar
6 oz,s will be fine..i usually run anywhere from 6-8 oz,s each in front depending on the rig
vonclod is online now   Reply With Quote
Old 02-15-2009, 11:07 PM   #3
I run a full pound in each of my front tires, So 6 oz is nothing.
1\4elliptic toy is offline   Reply With Quote
Old 02-16-2009, 09:19 AM   #4
Adding wheel weight is probably the single best mode I have done yet! I have 8oz in mine and it seams to be holding up fine. I'm sure it could be a bit better to if I trimmed the foam a bit. I have some HB rovers on the way there a bit bigger so maybe ill add a full pound like 1\4elliptic toy
smashmetal is offline   Reply With Quote
Old 02-16-2009, 12:14 PM   #5
Lead sticky weights are cheap, and you can always add more or take some off. I'm running 8 oz of steel weight front and rear but haven't tested it yet cause the wheather
http://i604.photobucket.com/albums/t...creeper015.jpg
http://i604.photobucket.com/albums/t...creeper017.jpg
look at the creepy rims thread for more pics
klip is offline   Reply With Quote
Old 02-16-2009, 01:48 PM   #6
the weights in the front like 6oz... no problem when you have more than a pound up there then you are pushing it.... they can snap the knuckles....
Old 02-16-2009, 02:14 PM   #7
Team Hardkor Crawlers
kasper's Avatar
As everyone else stated i also run lead stick weights 6 ooz in front
kasper is offline   Reply With Quote
Old 02-16-2009, 03:53 PM   #8
my vp revolvers are made for 6 oz of slugs. havent tried any more though
mwelch15 is offline   Reply With Quote
Old 02-16-2009, 09:42 PM   #9
you guys are great Thank you. I will probably be adding 2OZ more in each front.
AND A POUND!! wow, thats crazy
also, do you guys run any in the rear?
Old 02-16-2009, 10:02 PM   #10
I run 8oz in the front and 6oz in the rear.
RetVet is offline   Reply With Quote
Old 02-16-2009, 10:23 PM   #11
wow, ok. I find it really differnt crawling with weights in the wheels. But i do like it!
Ill buy some more lead tomorrow/
