Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Venom Creeper
Thread: Hex Adapters for ProLine 8 shooters
Old 03-05-2009, 08:14 AM   #1
Default Hex Adapters for ProLine 8 shooters
I have some new Proline 8 shooters with Rovers ready to go on my creeper. But I need new hex adapters that are wider then the stock ones. With the stock adapters the inside of the wheel is very close to rubbing. I guess I need new ones to give it more offset.
I don't know the size of the stock ones (width) but I know I need wider ones. Who makes some?
Thanks!
bassguitar is offline   Reply With Quote
Old 03-06-2009, 08:06 AM   #2
Anyone?
Old 03-06-2009, 11:57 AM   #3
Thanks!
maybe move to wheels + tires?
username is offline   Reply With Quote
Old 03-09-2009, 09:01 AM   #4
I don't think I understand your reply. Do you mean get new wheels and tires? Cause that's what I did. The ProLine 8 shooters are wheels, and the rovers are the tires. The problem is the Prolines have a deeper recess on the inside of the wheel and the wheel hubs rub on the inside of the wheel. I think with wider/longer hex adapters it would work okay but I still don't know where to find any or what brand makes loneger ones. I think it would need to be at least 10 mm wider. Maybe a bit less.
Old 03-09-2009, 09:19 AM   #5
I think he was saying to post in the tires and wheels sub-forum, you might get better results there...???
zerimar is offline   Reply With Quote
Old 03-09-2009, 09:26 AM   #6
Good call. Will do. Thanks.
