Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Venom Creeper
Thread: Venom creeper not creeping
Old 03-08-2009, 05:59 PM   #1
Default Venom creeper not creeping
Hey im pretty new to the rock crawling scene and apologize if im not posting in the right section. I just finished building my venom and installed a Tekin FX-R ESC with the TEKIN 55T motor and it is WAY to fast. i setup the ESC a couple of times and no difference. i am wondering if the venom itself is made to go this fast? or is it my ESC/Motor combo? My brother i was testing it with has an ax10 with a rooster/55t combo and drives nice smooth an slow.
808venom is offline   Reply With Quote
Old 03-08-2009, 07:19 PM   #2
It shouldn't be to fast. I have the same combo with stock gearing in one of mine and I think it is to slow. I run the fxr 45t in another creeper and think its just right. Your brothers axial and your creeper are most likely geared different and will make a huge difference in the torque and speed. You could always gear down with the pinion. Go to maybe a 12 tooth pinion (15 tooth is stock I beleive) or just be light on the trigger until you need the extra wheel spin.
hoplesshunter is offline   Reply With Quote
Old 03-08-2009, 07:47 PM   #3
Bingo!!!
RetVet is offline   Reply With Quote
Old 03-08-2009, 07:58 PM   #4
OK thanks. we played around in the garage pretty late so ust to test we piled anything we could to get some articulation with the trucks. I noticed at certain times extra wheel speeds helped. I just wanted to make sure i didnt blow anything up. still working out the bugs in the truck.
