03-22-2009, 07:08 PM | #1 |
Newbie Join Date: Feb 2009 Location: jerseyville
| go here about the front end work
i am on www.midwestrcc.com as RipIt,,,,,,,,,all the front end steering issues are posted there so you can see,,,,,,,,,so hope these photos will give you some ideas of your own............more to come ,,comped well today with a stock rig with a little redneck to help out the troubles,
03-23-2009, 09:14 PM | #2 |
| see if this works http://midwestrcc.com/forum/showthread.php?t=1267 like i said i am not a computer wizz,,,,,,,,,,just a shade tree mech. |
03-23-2009, 09:44 PM | #3 |
Pebble Pounder Join Date: Nov 2007 Location: Houston
Still cant see them unless we sign up for that site. Try using photobucket and then paste the image code into this thread. (its just copy and paste) .
03-24-2009, 05:30 PM | #4 |
| got pictures |
03-24-2009, 05:34 PM | #5 |
| my creeper |
03-24-2009, 06:51 PM | #6 |
Quarry Creeper Join Date: Feb 2009 Location: In The BackYard Crawlin
steering links on the back side.i like it,going to do the same.THANKS FOR THE PIX.
03-24-2009, 08:45 PM | #7 |
| dont forget
when you switch make sure you use the bent links to give you all the clearance you'l need.................took about 20min. once i found out what it took......................i drilled the spacers so a long shoulder bolt links it all together,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,the steering link was trial and era
03-25-2009, 06:57 PM | #8 | |
Quarry Creeper Join Date: Dec 2008 Location: Gardnerville
In the pics it looks like you used to stock tie rod. Are you saying that you used a bent lower link for a tie rod? | |
03-25-2009, 08:46 PM | #9 |
| end link
no i ment the end link has the offset,,,,but i think they were the stock ones,,,,,,,,,,,,,,,,and you can buy a piece of all thread, they make a brass one about the same diameter, it will bend easy by hand before you heat bend a traxis one, so you can build an easy template for length and bend to suit your likings
