Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Venom Creeper
Thread: 'clicking' in the driveline HELP
Old 04-07-2009, 09:14 PM   #1
Default 'clicking' in the driveline HELP
i have clicking that occures when i move from forward to reverse and vice versa....
i think ive narrowed it down to the vcd?s in the driveshafts...
any one notice this...
i saw where legion blew apart the front diff... but the clicking happens no matter where in the gear that the axels sit
paintz2007 is offline   Reply With Quote
Old 04-07-2009, 09:20 PM   #2
The only way you will really be able to tell is to take it apart and look at it. Hope its not something to bad.
legion1capone is offline   Reply With Quote
Old 04-07-2009, 09:27 PM   #3
how old is the rig?have you gone over everything making sure all the set screws are tight?
scram8 is offline   Reply With Quote
Old 04-07-2009, 10:02 PM   #4
Default set
the set screws in the drive shafts move,,,,,,check the c-hub pins first,,,,,,if they are too far off center they hit,
rip1969it is offline   Reply With Quote
Old 04-08-2009, 09:23 AM   #5
yea everything is locktited...
i might have to take apart the tranny and check the spur gear screws
o and its about 4 weeks old with about 5 intense crawling sessions on it
Old 04-08-2009, 01:17 PM   #6
cant you just take your drivelines out and check it that way.or does it only make the noise loaded.
