05-15-2009, 08:23 PM | #1 |
Rock Crawler Join Date: Apr 2008 Location: Greentown
| The washer mod...
alright. the washer mod... I didnt use washers, because its about 11 at night here and the hard ware store is to far to go in the dark on a bike... i used some wire I found and bent it into a circle till I could sandwich the bearing and the red locker. After that, your done! easy as that! Perminently locked diff... Ask if you need help. this makes the red thing unable to slide, so its locked and cant go any where. Good luck! I though I would post this up because I searched here and google and came up with nothing, then though about it and its quite simple. heres a pic (black thing between red thing and bearing is the "washer"): |
05-15-2009, 08:36 PM | #2 |
Rock Crawler Join Date: Dec 2005 Location: Mesa
I used a thin shock spring preload spacer/clip from some Associated units I had laying around. Same procedure on the install |
05-15-2009, 08:46 PM | #3 |
Should I change the title of the thread to washer/wire/shock spacer mod?
05-15-2009, 09:16 PM | #4 |
go ahead, i just put this up so people get the concept on how to do it. |
05-15-2009, 11:32 PM | #5 |
Rock Stacker Join Date: Feb 2009 Location: Tecumseh, MI.
Hey thats a good idea. Whatever works. I did what I think most are doing. Used a Slash body washer. Just trim it till it fits. |
05-16-2009, 06:14 AM | #6 |
nice! I was going to use a 1/8 washer, but when I drilled it out it broke in half :(.... this works fine, hopefully I dont need to do it to the front, but only time will tell.
05-16-2009, 10:43 AM | #7 |
Quarry Creeper Join Date: Feb 2009 Location: In The BackYard Crawlin
i was going to do that mod.when i got it apart found the three holes in the carrier were oblong and a chipped tooth on the spider gears.so i JB welded it together,intel i get the new aluminum carriers and spider gears.
05-16-2009, 01:08 PM | #8 |
I have JB welded gears too. works fine, this is easy and you dont have to wait for it to dry.
05-16-2009, 01:09 PM | #9 |
Rock Stacker Join Date: Mar 2009 Location: SGV, LA, CA, US
I did this with metal washers and ground them to the perfect inside and outside diamter. Fixed the problem for a few minutes of driving then the red rings pins one got sheered off and the other got loose then ended up sliding back and barely not engaging and ended up grinding the tip down at an angle. the last pin ended up just getting cut in half... EPIC fail for me... so I just ended up squirting JB weld inside the diff case. Great since. But this mod works but hopefully everyone else has better luck. :( |
05-16-2009, 02:26 PM | #10 |
Quarry Creeper Join Date: Nov 2008 Location: Slovakia
05-16-2009, 02:28 PM | #11 | |
| Quote: ouch! | |
05-16-2009, 02:37 PM | #12 |
05-16-2009, 09:58 PM | #13 |
Man that sucks!!! |
05-27-2009, 07:57 PM | #14 |
Newbie Join Date: Nov 2008 Location: US
Has anyone else just backed out the screw just to the left of the lock slide mechanism on the outside of the axle assembly to keep the slide locked in place?? I have 2 venoms with neither having the remote set up yet but both have the screws backed out a tad bit to keep the axles locked and to prevent backing back off. I know its a temp solution to the slider backing off but I havent had a single issue yet with either trucks locked diff not working or breaking.
05-27-2009, 09:34 PM | #15 |
Pebble Pounder Join Date: May 2009 Location: Sugar Land
Dumb question....what is the pupose of this mod?
05-27-2009, 09:56 PM | #16 |
Pebble Pounder Join Date: Dec 2008 Location: Cen Cal
to keep the axles locked. They like to pop out.
05-27-2009, 10:18 PM | #17 |
Even if you add the remote lock system?
05-27-2009, 11:03 PM | #18 |
No.
05-28-2009, 01:58 AM | #19 | |
| Quote: My diff case is even worse and pins on the ring a hard bended. Will not take any photos, coz you'll cry. Need also to check if the the edges are not damaged (i mean the edge of the axle where the bearing is seating) and this was my 3rd run, i have 3200lipo so it was not empty after all three short runs. I'd vote for alloy diff cases only or axial diff lock (if i remember right) | |
05-28-2009, 08:46 AM | #20 |
Pebble Pounder Join Date: Apr 2009 Location: Iron Range, MN.
3200 lipo? what are you running for a esc and motor combo?
