09-22-2009, 07:23 PM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: NE Ohio
| CVD Axle Pins measurements
I can't find my calipers to measure, but was curious if anyone knew the Length & Diameter of the pins. I would like to get some extras without buying axle shaft kit or driveshaft kit. Thanks Chris |
09-22-2009, 10:26 PM | #2 |
Pebble Pounder Join Date: Sep 2008 Location: Carlsbad, SoCal
Got my set of these in the mail the other day to try em, and they are the same size as stock. The replacement inserts that come with them are a bit smaller, but will also work fine. http://www.rc4wdstore.com/2/product_...roducts_id=789 |
09-22-2009, 10:29 PM | #3 |
Quarry Creeper Join Date: Feb 2009 Location: In The BackYard Crawlin
i use .078 piano wire.
09-23-2009, 06:19 AM | #4 |
Pebble Pounder Join Date: Aug 2009 Location: San Jo
whoa...piano wire.thats a good fix.i didnt know it came in that thickness.you may also want to try and find pin gauges made of HSS(same material as a standard drill bit). but they may be more expensive |
09-23-2009, 08:51 AM | #5 |
It looks like also a "binder clip" will work too in a pinch, since measures out the same O.D. needed.
09-23-2009, 09:25 AM | #6 |
Newbie Join Date: Sep 2009 Location: Plano
pretty sure they are 2mmx12mm
09-23-2009, 07:59 PM | #7 |
.078 Piano / Music Wire worked perfectly, onyly costed $.75 for 2ft and was able to cut a whole mess of them tonight. Chris |
