11-18-2009, 11:38 AM | #1 |
Quarry Creeper Join Date: Nov 2009 Location: Vacaville
| Venom stage X build....
Hey Guys, So as I'm in the middle of 3-linking the front on my 1969 Ford Crew Cab and doing some research over on the Pirate Board.... kept passing by the RC Crawling World Championships. Well my curiosity got me and I had to have a look.... So I decided that I would get my boy one for X-Mas and I could justify it as it would be much easier to run then our Nitro stuff! It's been nearly 20 years since I played with electric (RC-10, Ultima & RC10R). Now everything is smaller, more power and longer run times! I decided to get the boy a Venom Creeper and why not just get one for Dad also? So I ordered two, one red and one green! Since Dad doesn't have to wait till X-Mas, here is the build.... More stuff.... Great deals on these... Last edited by HRDROKN; 12-09-2009 at 12:40 PM. |
11-18-2009, 11:44 AM | #2 |
I figured since there has been some minor problems reported with parts inventory.... I'll start there. In the two kits, it looks as though I'm missing one lower shock cap (parts bag wasn't sealed) and that was on my boys red kit.... so plenty of time to get that resolved. |
11-18-2009, 11:52 AM | #3 |
Some have reported that the transmissions have been a little tight after assembly. I took some time going over each gear removing any obvious flash or high spots. Then I decided that I would run this trans in a bit... I applied some fine lap compound to the gears and ran them with my battery drill in both directions. Then I disassembled and cleaned all the parts. Trans feels much smoother now... I'm thinking that we will assemble the other kit omitting this step for a comparison. |
11-18-2009, 12:03 PM | #4 |
I assembled all the links... sorting out the 12* and 20* rod ends was a bit hard on my eyes! I'm either going to put together my own stage 2 upgrade or just get the CKRC kit. So this part of the assembly is on hold for a minute. I'm going to run the stock locker up front for now, but the rear axle will be getting the FLM Locker and still waiting on those parts. Front axle... Locker actuator... nice little design! Has anyone shimmed the pinion gear on these.... seems like there is a bit more backlash then I would like? |
11-18-2009, 12:07 PM | #5 |
Rock Crawler Join Date: Sep 2005 Location: Duncan, BC, Canada
one big tip is to use the regular cap style screws to 'thread' the transmission before using the flush head screws. the small 1.5mm head tends to round out standard allen keys so get a good quality 1.5mm and .050" allen wrench. The standard jobber wrenches will round out before long before you get any screws in. Also, if you are going to use the Locker (front?) get the alloy cases as well ... the plastic diff cases just don't hold up well. Add a small 3/16" band of 1/2" shrink wrap around the axle shafts CV joint ... it help prevent the pins from walking out over time. Once you get her built she's fun to drive. You'll need some 3mm x 30mm and an extra upper link, as well as an Axial chassis brace/tray mount to make your own 'stage 2' kit. Good luck, have Fun! Last edited by Rockfrog; 11-18-2009 at 12:13 PM. |
11-18-2009, 12:19 PM | #6 | |
11-19-2009, 01:54 AM | #7 |
Worked on some stage 2 mods today when I started thinking what the heck is a "stage 2", what is the design goal? Is it just a matter of a lower center of gravity? Is the addition of heavier springs and a travel stop due to the new layed back angle of the shocks? Does the stage 2 change the ride height? :? |
11-19-2009, 01:57 AM | #8 |
With that... I still have a bunch more to do, but here is what I have so far. Comments and/or suggestions welcomed. |
11-19-2009, 05:15 AM | #9 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
Thats a great idea, I was thinking of fabbing something up just like that.
11-19-2009, 12:30 PM | #10 |
Pebble Pounder Join Date: Dec 2008 Location: Cen Cal
Really good idea. A bit over built and heavy but sick none the less.
11-19-2009, 02:51 PM | #11 | |
Rock Crawler Join Date: Jun 2009 Location: Middleburg
bringing in your lower links. It works but you can make one for alot cheaper. All you need is 70mm upper links some nitro fuel line and stick on lead wheel weights, and some longer screws. Nice fab work, but that's alot of weight up top. The part i used for that stage two part was off an axial ax10( I cant find the part number). It was an upper support. You will still be accomplishing the same thing but with alot less weight. Also welcome to the addiction. | |
11-19-2009, 05:39 PM | #12 | |
Thanks for the info.... I will put that upper on a diet! | |
11-19-2009, 05:42 PM | #13 |
I was able to get a bit more work done today... I'm thinking that I will add some more swiss to that upper.. |
11-19-2009, 07:28 PM | #14 |
I tnink that I will also remove the shaded areas and drill more holes at the dots.... |
11-19-2009, 07:48 PM | #15 |
Rock Crawler Join Date: Mar 2009 Location: East TN
come on man, more pics! i did the same thing when i got mine with sorting and writing to avoid any surprises in the thick of it.
11-20-2009, 09:51 AM | #16 |
11-20-2009, 06:59 PM | #17 |
Newbie Join Date: Jun 2009 Location: Cantonment
real nice ideas
11-20-2009, 08:17 PM | #18 |
Rock Crawler Join Date: Apr 2008 Location: Greentown
I like that shock mounting plate. This is what some of out hop up companies need to put out!comon GH i hear this comming in orange ;D |
11-22-2009, 07:12 AM | #19 |
Any updates. I also wish that some of the aftermarket companies would start producing some hop-ups for the creeper, like this mount.
11-22-2009, 09:36 AM | #20 | |
