12-06-2009, 06:31 PM | #1 |
Rock Stacker Join Date: Nov 2009 Location: Seattle
| spring suggestions
Hello. I am curious as to what spring setups people are running. I am trying to combat the torque twist without installing the stage two suspension kit. My truck is stock with the exception of 60wt oil in the left rear shock. I would like to run stiffer springs and would like to know what you guys would suggest. I will eventually go to the stage two kit I would imagine, but for now I would like to keep it stock. Thanks for the suggestions.
12-06-2009, 06:37 PM | #2 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
I'm running red traxxas stock big bore springs with 60wt oil in all 4 and it handles pretty sweet, but I also have 70mm upper links. |
12-06-2009, 06:39 PM | #3 |
What traxxas truck are the spring for? My lhs carries a ton of traxxas parts, so it would be easy to get them. Nick looking truck! |
12-06-2009, 06:44 PM | #4 |
Tmaxx/Emaxx |
12-06-2009, 07:24 PM | #5 |
Rock Crawler Join Date: Apr 2008 Location: Greentown
I had the red big bore springs on but they werent long enough. I have the axial FIRM springs and killed the twist a LOT. It needs thicker oil still but i'm getting there. |
12-07-2009, 10:48 AM | #6 |
Madmax, pick yourself up some axial 70mm links for your uppers.
12-07-2009, 10:54 AM | #7 |
Quarry Creeper Join Date: Sep 2007 Location: NE Ohio
Stock Venom springs/shocks, with 90wt in the rears and stock (25wt) in the fronts. Works real nice and does a great job crawling & flexing. Chris |
12-07-2009, 01:26 PM | #8 |
Rock Crawler Join Date: Nov 2009 Location: OKC, ok
can someone throw out a link to some 70mm upper links please?
12-07-2009, 01:46 PM | #9 |
RCC Addict Join Date: Oct 2008 Location: Plainfield, IL.
12-07-2009, 02:00 PM | #10 | |
| Quote: awesome thanks alot | |
12-07-2009, 03:01 PM | #11 |
Pebble Pounder Join Date: Oct 2009 Location: NOSTRville
i run 80wt in rear and some stiffer sgrings that i found in my drawer of springs and shocks
12-09-2009, 01:55 PM | #12 |
Quarry Creeper Join Date: Jul 2009 Location: Derby
Axial makes 70mm links.. Got mine from the LHS for like $14 or something.. They didn't have any red ones though so I'm running green uppers and the rest of the truck is red...
12-09-2009, 04:05 PM | #13 | |
Pick up a can of oven cleaner and de-anodize the green, and use some aluminum polish you'll be all set | |
