12-06-2009, 06:35 PM | #1 |
Rock Stacker Join Date: Nov 2009 Location: Seattle
| What battery?
I am currently running a 2s 5000 lipo, and would like to go to a 3s setup that I could mount on the upper links or on one of the axles. What would you guys recommend, and what kind of run times can I expect? I am using a 55t tekin with a traxxas evx-2 esc. thanks |
12-06-2009, 07:25 PM | #2 |
Rock Crawler Join Date: Apr 2008 Location: Greentown
I dont think that ESC can handle a 3S can it?
12-07-2009, 07:27 PM | #3 |
Newbie Join Date: Nov 2007 Location: Indy
I have several 3s that I run. The smallest is a 1300 3s 15c and I get about 15-20 min on it. If I am getting wheels stuck and hung up a lot then it will be in the 10-15 range. I am running the Tekin FXR 55t combo. Chad Indy, IN |
12-08-2009, 05:51 AM | #4 |
Quarry Creeper Join Date: Sep 2007 Location: NE Ohio
I'm running a 2s Venom Lipo (1550) and I'm getting usually 1hr run times. My set-up is the following: Novak 55T & Rooster Crawler ESC and stock gearing. It has good wheel speed and perfect amount of torque I would change out that speed controler, not really the greatest for crawling. Chris |
