12-10-2009, 03:25 PM | #1 |
Rock Stacker Join Date: Oct 2009 Location: beaverfalls
| driveshaft problem solved
i figured out the driveshaft problem .. heres how to fix it take your stock driveshaft apart go get a losi 8ight exhaust hanger (these are extremly strong) and cut it a hair bigger than the origanal next drill out the metal inside of the driveshaft (sorry i forgot what its called) lol next put the pin in and and "pean it" (meaning smash the ends so they are bigger than the hole itself ) after you have "peaned the pin" get some epibond epoxy and put it around the pin lastly put some shrink tubing around the pin i dont think that pin is coming out anytime soon LOL problem solved Last edited by crawler-kid; 12-12-2009 at 02:14 PM. |
12-15-2009, 10:28 AM | #2 |
Rock Stacker Join Date: Oct 2005 Location: Somewhere in
That is a good idea. Hopfully you won't have to take them apart in the future.
12-15-2009, 11:31 AM | #3 |
Quarry Creeper Join Date: Sep 2007 Location: NE Ohio
I've found that a Rolled Spring Pin or Music Wire has worked the best and is readily available as well. During my intial build I did the heat shrink trick and the pin still ripped thru the heat shrink and the plastic DS. Since then I have upgraded to the Traxxas DS & Steel Yokes and have last alot longer then the original set-up and heat shrink trick Chris |
12-15-2009, 02:03 PM | #4 |
Quarry Creeper Join Date: Apr 2009 Location: Ottawa, ON, Canada
Peaned, epoxied, and heat-shrunk...a bit overkill but there's nothing wrong with that I like it and I think I'll try it as I bought spare driveshafts so no point in upgrading yet. Richard |
12-15-2009, 04:18 PM | #5 |
You don't have to worry about the pins coming out.
