12-11-2009, 01:51 AM | #1 |
Pebble Pounder Join Date: Sep 2008 Location: New Zealand
| 55t or 60t
I have read most of the threads here and have one main question. I am about to get a creeper and want to know a bit more about motor choice. My last crawler was a very choped and modded txt based super that was nice and slow and more torque than was healthy for the old axles. I like slow ( moderate walking pace ) and gobs of low down torque. I am considering the 60t motor as I have a pile of 48p tamiya pinions from 15-22t so I figured that with the stock creeper running a 55t on a 15t pinion I should be close with the 60t motor on the set of pinions that I have for a nice slow crawl. I like slow on the ground as my boats give me the speed on the water. For the Creeper when it lands here I will build and run it box stock....... and then go for the 70mm uppers, bta, split packs to lower cg, new shock mounts for added adjustment........etc. |
12-13-2009, 09:01 AM | #2 |
Rock Crawler Join Date: Apr 2008 Location: Greentown
I'd go the 60T if you have lots of pinions.
12-13-2009, 09:53 AM | #3 |
Rock Crawler Join Date: Nov 2009 Location: OKC, ok
o ordered the 60t venom off of ebay for mine. it gives you the brisk walk speed you want. and was only like $17 is to my door.
12-13-2009, 03:28 PM | #4 |
Quarry Creeper Join Date: Sep 2009 Location: TXRCO
I vote a 55t. They are probaly so close to know the differncne between them anyway.
12-13-2009, 04:22 PM | #5 |
Thanks for the input so far, if it makes any difference I'll be running 6 standard sub-c cells on this on. My lipos are for my boats (for now) I have a lot of loose cells GP3300, IB 3600, 4200. So I can make packs to suit. I'll wait for the Creeper to get here and then sort out cell configuration later. |
