01-13-2010, 06:22 PM | #21 |
Quarry Creeper Join Date: Oct 2009 Location: Newton
just out of curiosity, if you were to make the battery tray/servo mount out of Delrin... what thickness would you use? Also would you use the same thickness to make the chassis and skid?
01-14-2010, 08:47 AM | #22 |
Pebble Pounder Join Date: Nov 2009 Location: joliet
3/16"
01-14-2010, 04:17 PM | #23 |
Rock Stacker Join Date: Feb 2009 Location: Denver
I am interested ... how did you physically mount the transmission to the chassis / skid plate ? Did you drill into it ? Really good sticky tape ? Pictures ?
01-14-2010, 06:07 PM | #24 | |
Quarry Creeper Join Date: Jul 2008 Location: Over a rock and under a bridge
1/8" G10 sheets. As for the transmission, the side w/ the small aluminum plate and those 4 screws is what I used to mount the transmission on its side. When I bolted the transmission to the skid plate, I had to remove to protruding plastic screw mounts (basically where your stock bottom links get screwed to on the transmission) to flatten it. The transmission and the aluminum plate were both secured onto the skid plate by 4 small 2mmx14mm machine screws. 2mm is small but it's holding up very well. Last edited by zoojunkie; 01-14-2010 at 06:10 PM. | |
01-14-2010, 06:13 PM | #25 |
01-15-2010, 11:58 AM | #26 |
Quarry Creeper Join Date: Jul 2009 Location: Derby
more pics!! definitely interested in this since it puts the tranny sideways... I like that concept |
01-16-2010, 03:24 AM | #27 |
Thanks! I will get some more pics on the rocks we crawl this coming week. |
