01-11-2010, 10:33 AM | #1 |
Rock Crawler Join Date: Oct 2009 Location: OUT THERE
| running 1.9s
does any one know if the axial scx10 wheel hubs will fit the creeper or if anyone makes smaller ones so i can run 1.9 on my creeper scale build.I dont belive the 1.9s will clear the stock ones, is any one running 1.9 on their creeper thanks.
01-12-2010, 11:55 AM | #2 |
Any one? Do any of you have a creeper and a scx10 , if so could you please throw on the 1.9s to see if they will fit on the creeper with no problems or rubbing thanks.
01-12-2010, 12:07 PM | #3 |
Rock Stacker Join Date: Feb 2009 Location: Denver
I have the creeper and a artr axial and I can swap the tires and rims back and forth and it works just fine .... not sure about the 1.9 tho ! |
01-12-2010, 12:30 PM | #4 |
Quarry Creeper Join Date: Sep 2007 Location: NE Ohio
There was a thread in here by "Sloppy" that had worked on a 1.9 Creeper. You might be able to search via name, or look thru the pic archive, from last to first to spot his name. Chris |
01-13-2010, 03:03 PM | #5 |
Thanks I saw sloppys build but he had 2.2s on it just want to know if they will work for sure before I order any so if any one could confirm that the 1.9s will fit I sure would appreciate it thanks again.
