01-16-2010, 10:54 PM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Deltona, FL
| Snapped a C-Hub
I'm thinking a pin worked it's way out of the CVD, and caused a bind to snap the C-Hub. |
01-17-2010, 07:12 AM | #2 |
Rock Crawler Join Date: Apr 2008 Location: Greentown
I just broke one to. GOod thing it comes with 4 when you order and they are cheap.
01-17-2010, 07:52 AM | #3 |
Quarry Creeper Join Date: Sep 2009 Location: TXRCO
| Best carnage I've seen yet on the creeper!
01-17-2010, 08:33 AM | #4 |
01-17-2010, 08:34 AM | #5 |
Pebble Pounder Join Date: Dec 2009 Location: Who Dat Louisiana
I just replaced one too. We got a little rough playing king of the hill at our lhs layout lol. Had to buy plastic since everyone was sold out of aluminum c's.
01-17-2010, 08:39 AM | #6 |
So is this part worth it in aluminum then? I have 2 of these so any upgrades, I need to do x2 for the kids.
01-17-2010, 12:31 PM | #7 |
I would say the aluminum c's would be a good upgrade. The stock c's are strong, but if you play hard, I would buy a set to install. Then you'll have extra stockers for the other creeper |
01-17-2010, 12:35 PM | #8 | |
From looking at what broke....I think the pin worked it's way out, and bound up the VCD, and snapped the C hub. Had some aluminum tape around the CVD, but obviously not enough to keep the pin in. Maybe next time put a set screw on both sides of the CVD joint. | |
01-17-2010, 01:18 PM | #9 | |
Rock Crawler Join Date: Sep 2005 Location: Duncan, BC, Canada
01-29-2010, 05:46 AM | #10 |
Quarry Creeper Join Date: May 2008 Location: Ontario, Canada
I did the shrink wrap and so far no issues.....the brass tube mod make alot of sense though!!
02-07-2010, 09:39 AM | #11 |
Newbie Join Date: Dec 2009 Location: clemson
Well just did the same on mine... Snapped the driver side c. What aluminum ones are yall using? Do the axial ones work?
02-07-2010, 09:49 AM | #12 |
I joined the Band! Join Date: Apr 2007 Location: norfolk
| Has anyone tried to see if the threaded parts are threaded all the way through on your rigs? I noticed that mine was not. If you have a 2.5 hex Screw you can run that all the way through to tap it. Mine was not threaded all the way and the screw was not making tight contact with the pin. Now that I have done this I get a tight normal fit. It is worth a try."thumbsup"
02-07-2010, 09:59 AM | #13 |
Rock Stacker Join Date: Feb 2010 Location: american fork
haven't done it but from what i have read ,yes ,the axail alluminum c hub's work on the venom!!
02-07-2010, 03:24 PM | #14 |
02-07-2010, 03:36 PM | #15 |
Rock Crawler Join Date: Jun 2009 Location: Middleburg
02-07-2010, 03:38 PM | #16 |
02-07-2010, 04:12 PM | #17 |
02-07-2010, 05:21 PM | #18 |
Rock Stacker Join Date: Aug 2009 Location: Munfordville
mine did the the same thing, I wrapped mine with electrical take and no more problems. its a cheap solution.
02-11-2010, 07:43 PM | #19 |
Pebble Pounder Join Date: Jul 2007 Location: Selangor
02-11-2010, 09:40 PM | #20 |
Well no need to "make" them work. A few venders have the HR c-hubs in stock. Just ordered mine . And the other online stores should be getting them too.
