01-31-2010, 10:23 PM | #1 |
Quarry Creeper Join Date: Dec 2009 Location: Central IL
| weight distribution
Has anyone done the math and found out which weight distribution works best for them? I ran the calcs and added enough weight to the front to make my rig 60/40. It definitely helped, but I haven't played around with other combos to see what works best. My biggest issue is I'm still hanging up on the front of my trans. I need to build a skid. Anyways, just seeing what everyone else is doing. |
02-01-2010, 10:07 AM | #2 |
Pebble Pounder Join Date: Dec 2008 Location: Cen Cal
8 cell and a 35t motor will help.
02-01-2010, 12:17 PM | #3 |
Pebble Pounder Join Date: Dec 2008 Location: Eastern, Oregon
| I dont know the specifics of my bias but I like to add as much weight to the front without adding any to the back. This makes my rigs go up inclines like mad but you really have to drive going down hill. Its all personal preferance. |
02-01-2010, 12:20 PM | #4 |
Rock Crawler Join Date: Nov 2008 Location: Beloit,ohio
| I also run 60/40. For decents its way more pridictable. |
02-01-2010, 03:38 PM | #5 |
| Will help with what? How does that have anything to do with the weight ratio f/r? I've been using 60/40 for the past couple days. Seems to be working well. I can climb as steep as my tires will have traction so I guess that's good enough. Now for some new tires... |
02-02-2010, 10:46 PM | #6 |
Newbie Join Date: Jan 2010 Location: lake sahstina
are you adding weight or just placing the batery and eletronics more twords the front ?
02-02-2010, 10:50 PM | #7 |
Adding wheel weight. The heavy electronic components are pretty limited in mobility due to packaging constraints. Figured I'd leave em where they're at and add weight to the front wheels to give me the weight distribution I was lookin for.
