02-05-2010, 07:27 PM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: north phoenix
| binding question
when you first built your creeper did it seem tight just rolling it by hand... i mean when i grab the wheels and turning it by hand i seems tight.... any input would be appreciated
02-05-2010, 07:32 PM | #2 |
RCC Addict Join Date: Oct 2008 Location: Plainfield, IL.
I couldnt even spin my trans from the output shaft via hand. My trans had a real rough spot, so i opened the holes where the bearings go, just a little bit, giving the gears some room to seperate a little bit when the rough spot came around making it super smooth. If you do this remove a little material then check, then a little more ect, if you remove to much and allow the gears to spread to much they will strip. I also ran my trans on a drill while greased for 2 packs afterwards.
02-05-2010, 07:36 PM | #3 | |
ill try that what did you use tool wise.... what about in the wheel area any binding there Quote:
02-05-2010, 07:55 PM | #4 |
| I used the tip of a 1/2" hole saw, I had no binding in the axles, if you do, check your cvd pins, make sure your hexes arnt rubbing the axle casing, and make sure your wheels arnt on to tight. |
02-05-2010, 08:09 PM | #5 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
02-05-2010, 09:04 PM | #6 |
02-05-2010, 09:35 PM | #7 |
Pebble Pounder Join Date: Dec 2009 Location: Buffalo
Its tight. Make sure pinion mesh is correct and try it out. Until its broken in its very hard to turn the trans by hand with the driveshafts. |
