02-07-2010, 10:51 PM | #1 |
Newbie Join Date: Jan 2010 Location: Walnut Ca
| Any problems with the DIG for the creeper?
Hey guys I'm thinking about getting a DIG unit for my creeper and I was just wondering if you guys have encountered any problems with it.
02-08-2010, 12:38 AM | #2 |
RCC Addict Join Date: Oct 2009 Location: Nanaimo, BC (Vancouver Island)
Mine tends to jam if your on the throttle while shifting it, it works good if you shift it while stopped. The odd occasion it seems to stay locked because I have pressure on the gear from digging it doesn't want to shift but a couple shots on the throttle usually gets it to shift. I'm hoping with more use it will start to shift a little better but time will tell.
02-08-2010, 01:05 AM | #3 |
Quarry Creeper Join Date: Dec 2009 Location: Central IL
Do you think it would shift better with a stronger servo?
02-08-2010, 01:15 AM | #4 |
I'm using a hitec hs225mg rated at around 60 or so ounces at 6v, stk venom is rated at maybe 30 oz
02-08-2010, 05:13 AM | #5 |
Rock Stacker Join Date: Oct 2009 Location: Canada
I'm using a Hitec HS55 and my dig unit woks great
02-08-2010, 07:57 AM | #6 |
02-08-2010, 10:51 AM | #7 |
Pebble Pounder Join Date: Nov 2009 Location: joliet
not if your endpoints are set correctly mine works the best if your in the throttle a little bit like at crawling speed if you try to shift it while at full throttle your bound to break something sooner then later
02-08-2010, 11:14 AM | #8 |
Pebble Pounder Join Date: Sep 2009 Location: Newark
I don't have any problems with it. I don't recommend shifting into it on the fly though. Remember your trying to take two gears and mesh them, think of the problems you coulc have if they are not alligned properly. It may take a slight tap of the throttle after shifting the gear to make sure everything is fully engaged.
02-08-2010, 11:22 AM | #9 |
Not sure what the design is but theres applications where gear meshing occurs on the fly, such as some late model transfer cases. Just saying.
02-08-2010, 08:17 PM | #10 |
Rock Stacker Join Date: Oct 2009 Location: Arlington
Bray d: its totally unsynchronized. The lever arm that actuates it has a spring on it that is used as a bs meshing device so if the teeth are not aligned something will give and hold pressure till the splines align. kurtus: you can tighten the nut on the very bottom of this lever to tighten the preload of this little arm thingy (<--venoms technical term) and it may help with your servo engaging the driveline disconnect under load. |
02-08-2010, 09:36 PM | #11 |
I figured they wouldn't get that in depth with it. I've had the t-case apart on my 1:1 many times, and the shift of the fly is possible due to the way the actual gears are cut. Sounds like increasing the preload on that spring may solve the problem. Since its a spring that's actually providing the force to engage the gear, depending on the stiffness of the spring, a higher torque servo wouldn't even be necessary. Unless it was having a hard time disengaging of course. I'll be reading up on the Vemon Dig threads. I may have to fork over the cash for one with my tax returns. |
02-09-2010, 12:31 AM | #12 | |
02-09-2010, 09:58 AM | #13 |
Yea I have to say I am a little unimpressed with it. I have thought to go so far as to cast my own gears and to sharpen up the mating splines so they will cram together under high load, but its a lot of work, and I had hoped that venom would have done all that. ho hum it just means other guys have an advantage in the comps sometimes dig climbing and such.
02-09-2010, 10:16 AM | #14 |
Yeah it's definiatly not the end of the world for the most part it works decent, you can check out some vids of snwchris and his creeper @ s&n trackside to see it in action on a coarse. He seems to be managing pretty well with his, I think it's just learning the best senario for using it.
02-09-2010, 07:08 PM | #15 |
Newbie Join Date: Nov 2007 Location: Indy
I am actually using the diff lock servo with no problems I did away with the top battery tray and used the diff lock servo mounted on the frame. I am sure the servo will fail at some point, but it has been in there for about 5 months.
