04-06-2010, 03:53 PM | #1 |
Rock Stacker Join Date: Nov 2009 Location: Socal
| Homemade stage 2 kit
I searched for it but couldnt find much about it. So i want to see what you guys came up with for your homemade stage 2 kits.
04-06-2010, 04:28 PM | #2 |
RCC Addict Join Date: Oct 2008 Location: Plainfield, IL.
If you want, i have the braces and spacers from the ckrc kit..... All you would need to do is limit your shocks and get some axial springs and your golden. EDIT: I also have some 70mm upper links as well Last edited by InFlames; 04-06-2010 at 06:13 PM. |
04-06-2010, 04:43 PM | #3 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
What lenght braces are used anyways? for mounting the shocks inside the chassis and on the rear... thanks.
04-07-2010, 09:24 AM | #4 |
Pebble Pounder Join Date: Nov 2009 Location: joliet
the venom stock uppers are used with spacers in the rear. it wont work in the front so they supply a plastic bent brace for it, i believe axial makes one in aluminum. I dont really need them since i left my tray up top |
