04-09-2010, 07:30 PM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: Bettendorf
| HR Lock Outs For Creeper
I am having trouble with pin in the axle set coming loose on my creeper. The grub screw that are supposed to keep the pin from slipping out don't seem to be doing a good job. If i understand correctly the HR lockouts replace that part so that you don't have to fool with pins and grub screws. Is that correct? The parts I saw were for the rear axle is there something similar that can be used on the front axle? Exactly what parts do I need? Thanks! Mike
04-09-2010, 07:48 PM | #2 |
Newbie Join Date: Mar 2010 Location: Bay Area
Look up Loken Racing's brass sleeves that cover the pins, $7 for a set of four. The HR lockouts are to remove the rear knuckles and have less to hang up on obstacles, I don't think you are looking for these.
04-09-2010, 08:17 PM | #3 |
| Loken Found the site.. didn't see the part. I sent them an email. Thanks for the tip.
