04-10-2010, 08:08 PM | #1 |
Newbie Join Date: Mar 2010 Location: waterloo
| why is it doing this??????
so i got my kreeper kit put it all together to the 't' but when i run it in forward it seems to be when i want to go real slow it is skiping but when i go slow in reverse it is nice and smooth what could this be (and i have already took the front and rear axles apart to check them)???????
04-10-2010, 08:12 PM | #2 | |
Rock Stacker Join Date: Oct 2009 Location: beaverfalls
04-10-2010, 08:27 PM | #3 |
no i tryed tighting the lock screw on the locker and then i tried taking them right out and it is still doing it??
04-10-2010, 08:30 PM | #4 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
Could be your ESC or motor or even some form of glitching. How bad is it? did you reverse the motors wires to see if it still happens only in forward? Start trouble shooting it to eliminate what is not wrong with the truck and you will find out the casue of the problem.
04-10-2010, 08:38 PM | #5 |
ok ill try it it wont hurt it if i switch the motor wires??
04-10-2010, 08:40 PM | #6 |
04-10-2010, 08:41 PM | #7 |
ok so i switched them and now it does it in reverse?
04-10-2010, 08:47 PM | #8 |
04-10-2010, 08:59 PM | #9 |
so then yes it is still doing it when the motor is going forward so how do i fix this???
04-10-2010, 09:01 PM | #10 |
04-10-2010, 11:19 PM | #11 | |
Newbie Join Date: Aug 2008 Location: saline
He stated that after he swtiched the wires (as you requested) the glitch is now happening in reverse. Keep Creepin, Is it smooth going forward now? Now skipping in reverse only? If so it sounds like a motor esc issue. What motor and esc are you using? | |
04-11-2010, 08:53 AM | #12 |
well i got it i just had to reset my esc and reprogram it now it is as smooth as ever thanks for the help guys!!!!
04-11-2010, 10:57 AM | #13 |
