04-27-2010, 08:33 PM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: north phoenix
| new and improved......
Check it out i got parts in this past week fromTCSCRAWLERS.COM up'd my trans to an ax10 (locked version) and also got TCSCRAWLERS.COM's delrin skid plate its lighter, tougher, smoother its like butter on rocks... mmmmm butterrrr! Comments are welcome...... before after delrin skid plate |
04-27-2010, 08:59 PM | #2 |
Rock Crawler Join Date: Feb 2010 Location: eugene
looks good man. ive done the same. im waiting on my delrin skid though...looks alot cleaner. thats one of the best changes that ive done to my creeper. makes just doint maitnece stuff so much easier and lower your cog a little bit. may want to look into some integy drive shafts...also you can get a dna dig on this site for $35....i ordered 2, one for my creeper and another for back up...
04-27-2010, 09:00 PM | #3 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
whats the difference in weight between the two trannys?
04-27-2010, 11:22 PM | #4 |
04-28-2010, 08:07 AM | #5 |
RCC Addict Join Date: Jan 2010 Location: Barboursville, WV
04-28-2010, 10:38 AM | #6 |
Quarry Creeper Join Date: Dec 2009 Location: Santa Cruz
I think the biggest difference would be size. I was thinking about the RC4wd R2.. But that Axial one looks great in there. The Axial skid gives better ground clearance. My friend did the Axial skid with the R2 and it rocks . How much did the Axial Trans cost??
04-28-2010, 02:08 PM | #7 | |
37.99$ for locked trans 24.99$ for delrin skid plate...... i dont remember the wieght difference but it was a considerable amount i weight it with all the metal attached ( stock trans ) and with the motor plate on the ax10 trans. still a considerable amount.... | |
04-30-2010, 11:32 PM | #8 |
did the ax10 trans come complete or did you have to buy a spur gear,,other parts,, to bolt it in and make it work. all the ads ive seen for the ax10 locked trans shows it with out a spur gear or gear mount/slipper mount, meaning you buy the trans and a spur gear and the gear flange for the primary input shaft. |
04-30-2010, 11:55 PM | #9 | |
came complete in a assembly bag with all parts except for the spur gear yes i had to purchase one | |
05-01-2010, 12:02 AM | #10 |
i wish they would clarify that in the ads for these,,," requires spur gear for install"
05-01-2010, 02:07 AM | #11 |
05-01-2010, 07:17 AM | #12 | |
Rock Stacker Join Date: Oct 2009 Location: canada
I have a used axial trany on the way. Is the axial skid plate the same width as the venom? Last edited by muddertrucker; 05-01-2010 at 07:46 AM. | |
05-01-2010, 10:51 AM | #13 | |
the axial skid plate is only a couple of mm wider. the dna dig is here http://www.rccrawler.com/forum/showthread.php?t=204553. buy a couple of them, one for your rig and one as back up. last weekend mine went out after a months of use but i think a glitching radio system started the problem (which i recently fixed). the reason i say to pick up a couple is that due to dna is no longer in busness, damn stupid economy | |
05-01-2010, 09:30 PM | #14 | |
ya i had to drill holes on the chassis plate not so far off to make the skid work but... tell you what it is well worth it... | |
05-01-2010, 11:42 PM | #15 |
hey side, theres a comp coming up just north of you in little over a month at watson lake, prescott. AZ Summer Shootout 2010 June4-6 i was just telling some friends about it. wish i was back home to go, but im stuck here in stinky hippyville of eugene oregon. that will be some good crawling on the granite..... |
05-02-2010, 11:21 AM | #16 | |
i was gonna check that one out... | |
05-02-2010, 02:48 PM | #17 |
BTA done!!!!! and i didnt have to buy or machine anything and still using the ckrc stage dos'...... a bend here and a bend there.... spacer here a spacer there..... presto chango! BTA!!!! i will be posting this on the tips and tricks...... taking pictures now so give a couple hours it will be up
