06-01-2010, 01:07 PM | #1 |
Rock Stacker Join Date: Jul 2008 Location: WNC
| Need Inspiration to See It Thru
So I got a Creeper, took me 3 months working on and off on it to get it all together. I just didn't have the desire to work with it like I do with other RCs. After it was all together, I have managed 30 minutes run time. The gear box is a hoax in my opinion. Seems impossible to mesh spur/pinion. Now the thing is sitting here in half waiting on me to decide to try and get the gears/motor to mesh. Or maybe just give up and sell it. I have $325 in it with the electronics. Another thing is I haven't got the diff locks to work. Is my experience 1 in a million?
06-01-2010, 01:17 PM | #2 |
Quarry Creeper Join Date: May 2005 Location: Ontario, Canada
Sounds to me like your having a bad luck experience. My gear mesh is perfect.. as you work on other rc cars and such how do you setup gear mesh's for those models? I use a piece of paper and pinch it between the gears to set the motor in the perfect spot. I also enjoy other RCs: 8th scale buggy racing, 10th touring electric. but i drive my crawler hands down 3 times as much or more.. |
06-01-2010, 01:32 PM | #3 |
I have gone through many RCs. At this moment I have a 4z2 Slash, 4x4 Slash and a Rustler. The Creeper's gearbox is the worst thus far. I don't see why the motor wasn't instructed to bolt on back in the early steps. All the video's I've seen for the Creeper appear to work for a long time without problems. Then I get a lemon or did I?
06-01-2010, 01:56 PM | #4 |
Rock Stacker Join Date: Jan 2010 Location: Vacaville
if you read the tips and tricks post and other builds everyone recommends just what you said. to install motor as soon as trans is doen being built. I know it doesn thelp you now but I would drop the trans and set the mesh right one time. you will get alot of run time once set properly. goo dluck. dont give up..oh and btw I owuld ditch the locking diffs and switch to lockers for both front and rear. Even if you ge tthe lockers set up right they wont lasst as long as the rest of the truck...
06-01-2010, 07:24 PM | #5 | |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
06-01-2010, 08:14 PM | #6 | |
haha i knew someone would ask how to do the paper strip method. its honestly a PITA.. i kept trying and trying to get the paper in there without dropping it.. it finally went in to place and I got the motor tightened down.. I am scared to make any adjustments.. lol however, i have a RC4WD R2 on its way.. so much easier to deal with.. plus its all metal gears.. cant go wrong for $59.** | |
06-01-2010, 08:30 PM | #7 |
Rock Stacker Join Date: Oct 2008 Location: Toronto
it was easy for me. I install my motor last. Put the motor in, and put the screws in, don't tighten it yet, but don't let it too loose. Shine a flashlight in and see the mesh, once you get a good mesh , tighten one screw, double check and readjust(if needed) the mesh again, then tighten the other screw. Then do a final tightening of both screws. You need a proper hex driver and a flash light. Also, hold the motor hard against the mount, so you don't move the mesh. |
06-01-2010, 09:20 PM | #8 | |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
Heres what I have come up with for workin on the Creeper Tranny,,,, You need: 1/4" or larger drill bit up to about 3/8" I wouldnt go larger A drill ot drill press remove the transmission gears from the tranny, you do not have to remove the tranny from the chassis though the pics below pretty much explain what I did to my reserve tranny and what I am about to do to my in-use tranny. I drilled two 1/4" holes in the tranny to see into it at the motor end. | |
06-01-2010, 11:05 PM | #9 |
Rock Crawler Join Date: Feb 2010 Location: eugene
thats a good idea rmdesignworks. i was thinking of doing some what the same but was going to put a hole in the case the size of my finger but never got around to doing it....i decided to run a axial trans....and thats been working out great for me...
06-01-2010, 11:51 PM | #10 |
Rock Crawler Join Date: May 2010 Location: CRAWlORADO
with the motor mesh drop the rear springs out of the way including the battery tray if using one take the rear drive shaft off from the gear box then open the gear box from the rear (make sure that the gears are still in place in the box) put the motor in and get the screws in but do not tighten then hold the motor to fit the gears(not too tight or lose enough to freely move side to side). spin the the front tires so that the gears move you will see that the motor will position it self so that it is not to tight or lose on the gears as soon as you can see that it is right tighten the screws and put every thing back together. trial and error for me and that seems to work the best. GOOD LUCK! the creeper has been awsome for me with the new xvds,flm lockers and the dig.
06-02-2010, 01:54 PM | #11 |
Today I got into the tranny. Took out all the gears and discovered the spur was nearly bare on one side. I also made note that I had mounted the pinion wrong. The spur was eaten at an angle = to the pinion. I will have to order some new spurs from TH before trying again. At least now I know the errors of my ways. I got into the tranny basically the way jojo303d said. I guess it's like any other RC, there's always something to go wrong. I just wished I had more minutes, even hours into running it.
06-06-2010, 10:43 AM | #12 |
Rock Stacker Join Date: Feb 2010 Location: american fork
I just made a allen that was about 6 in long and adjusted it that way i have had many r/c's so adjusting the backlash is a feel thing to me anyway. the hardest part is getting the screws started i think! and , I totally agree with you that they should have in the instructions to put the motor in way before the rest of the truck is built . i love my creeper ! it only took me a day or so to put it together! but thats just me . i live in utah so i have ALL kinds of rocks to climb here and many other obsticles. there are four canyons within 15 -25 miles of here (wasatch front ) that have KILLER places to play!!!!!!!!! |
06-06-2010, 10:56 AM | #13 |
Newbie Join Date: May 2010 Location: Steamboat Springs
Put a dab of grease in the head of the screw, this will help keep it on the allen driver.
06-06-2010, 11:34 AM | #14 |
Quarry Creeper Join Date: Feb 2010 Location: muskegon
