06-11-2010, 08:22 PM | #1 |
Rock Stacker Join Date: Jul 2008 Location: WNC
| gear box
Has anyone here ever pull the Creeper's gearbox out and exchange it for something else. I should hope that I'm not alone, but if you read over my posts on this forum you know by now that I haven't had success with my Creeper. I am learning to hate the thing more as time goes by. After ordering new spur gears and installing it, the pinion decided to fail again. I hate (don't like using that word) the gearbox. So much that if the truck don't run after this weekend, I'm done with it. |
06-11-2010, 09:06 PM | #2 |
Rock Crawler Join Date: Feb 2010 Location: eugene
lol, i just posted in your thread in general...as i never had the problems your having with your trans, i put a axial in mine just due to easier matnience....like getting to the motor. all you will have to do is drill 2 holes per chassis side plates and put in some sort of axial trans mount and skid. the trans kit http://www.ckrccrawlers.com/ax30487a...ons-p-350.html stock trans mount (will have to mod to keep lower links between plates) and currently using, have strc delrin that ive been to lazy to install http://www.ckrccrawlers.com/ax80007a...set-p-355.html delrin skid option http://www.ckrccrawlers.com/axialrac...age=3&sort=20a and a spur gear http://www.ckrccrawlers.com/ax30672a...87t-p-673.html you also nees some screws and nuts and your choice of drive shafts heres a pic of mine when i was first installed it and the brown thing hanging off of the back is a dna dig unit... |
06-11-2010, 10:31 PM | #3 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
do you have a crawler group near to you,,it sounds like you need some tech support on set up and ongoing upgrades. the big thing about these rigs unlike a lot of rc types is that in order to be good they have to be made good from the start. there a re a lot of second grade parts out there that are said to be good that arent. we buy our parts from hundreds of different vendors worldwide and not all of them are selling the best quality. some people are buyin cheap from companies overseas and getting products made from lower grade materials that after a short time,,break. it sounds like youve had a run of bad luck and i dislike seeing anyone suffer along with something they dont enjoy,,if you cannot get staisfactory results from your lhs or a nearby group then let me know and we can work out something to get your rig to me and i will be happy to look it over and see what i can do to help you out. this is a hobby and should be relaxing and enjoyable,,it should not be a task or job to take part in. |
06-12-2010, 01:24 AM | #4 | |
Pebble Pounder Join Date: May 2010 Location: Earth
Just opened my box for inspection after 15 hours of driving and there was absolutely no visible wear on the gears, everything was like theyre supposed to be. Youve must done something wrong when assembling that gearbox and if your spur and pinion fails, thats usually because your gear mesh is set wrong. Just my 2 cents.. | |
06-12-2010, 12:18 PM | #5 |
| In response to your 2 cents, I followed the manual as close as possible. The truck ran for 15 minutes and while the diffs were unlocked, the spur stripped. I ordered several new spurs just in case. After reinstalling the new spur, the truck once again ran for 8 minutes with the diffs locked, then the motor started whining and the truck just sat still. All the while, steering works. With my kit, I added the Novak Rooster Crawler/Fifty-Five 55T Brushed System. I looked into the gearbox and noticed everything was fine except the pinion was not moving. So to try something different I asked my brother to take a look at it. He removed the motor and the pinion fell off like it wasn't screwed enough. After resetting the set screw and meshing it for the 3rd time with the spur, he reassembled everything. Once he gave the throttle a pull, the truck just sat still and the motor whined. I believe everything has been done that can be with the pinion and spur. It has got to be the motor at fault.
06-17-2010, 08:32 PM | #6 |
Finally! Today after one more try this week, my brother and I got all the gears meshed correctly and took my Creeper out to the rocks. I must say I was pleasantly surprised as it crawled. It got stuck on sharp rocks on twice. It ran along side a Axial Scorpion that had a brushless motor and a lipo. Needless to say the shinny red aluminum is scratched now and it boldly states "I have left the building!" Now comes my decision as whether to keep it or not. I still despise the gearbox and favor that of the Axial. Other than that, I like everything else better on the Creeper. Thanks again for everyone's help on here. |
06-17-2010, 08:37 PM | #7 | |
Quarry Creeper Join Date: May 2005 Location: Ontario, Canada
06-17-2010, 10:24 PM | #8 |
The R2 tranny's are freakin great and stout as hell,,but for all that stout,,you almost triple your low end weight right above the axle line,,,I agree on going Axial for a trade out tranny but the R2 is really more for a scaler, the added weight will hurt most on vert's and sidehills.
06-18-2010, 07:50 AM | #9 | |
Got a reasonable link for purchasing? | |
06-18-2010, 08:31 AM | #10 |
please read the second (my) post.....i also posted a pic of after i installed it with links....
06-18-2010, 07:13 PM | #11 |
06-18-2010, 07:27 PM | #12 |
06-18-2010, 08:12 PM | #13 |
